;-) 2025 NGWCLUB Calendars now on sale :-)
viewtopic.php?p=828681#p828672
rear brake rubbing
Steevensi
rear brake rubbing
Post by Steevensi »
Hi,
I noticed this week that the rear brake disc is rubbing against the pads.
My guess is there there is dirt or something that prevent the pistons to retract completely.
Is there a procedure somewhere on how to clean lubricate them?
Thanks
The Black Bike
http://www.ngwclub.com/forum/viewtopic.php?f=30&t=59312
1982 GL 1100
1980 GL 1100 to be fix
1983 Honda Nighthawk 650 sold
1982 Honda CB 750 K under construction
1980 Suzuki A100
1974 Suzuki TS 250 sold
1992 Yamaha RT 180 sold
1976 Honda CB125 sold
2002 Suzuki Katana 750 sold
1983 Suzuki GS770 rusting in a shed
1982 Suzuki GS750 in boxes
Re: rear brake rubbing
Tap it with a rubber hammer and see if it helps. Could be the pins that the caliper center on are sticking. Pull them offand lube them. Can't hurt. and is easy
Steevensi
Post by Steevensi »
Ok i'll try that. Thanks Cyborg
The Black Bike
1982 GL 1100
1980 Suzuki A100
Let us know how it works out
Rubbing how bad? They will always touch a little. That is normal. But if they are dragging then yes, it needs looked at.
Steevensi
Post by Steevensi »
Not that bad. On the stand, if i push it hard with my hand, it will do a couple of turns, but i can hear it rub lightly
The Black Bike
1982 GL 1100
1980 Suzuki A100
A couple of turns isn't bad, IMhO. Still, if you're unsure about how well it's operating, a good cleaning isn't going to hurt anything...
Steevensi
Post by Steevensi »
Yeah i will clean it anyway.
The Black Bike
1982 GL 1100
1980 Suzuki A100
Don't forget the dreaded 'spooge' hole :guitar
That's the teeny tiny return hole in the MC .....
If you can spin the wheel 2 revs I'd say ride it and don't worry about.
KYpondman
Post by KYpondman »
robin1731 wrote:If you can spin the wheel 2 revs I'd say ride it and don't worry about.
+1
Claude
