Exhaust leak nose but no leak?
HorseFly
Zinc Member
Zinc Member
Post by HorseFly »
My 82 GL1100 started getting nosy on the right side like the exhaust is leaking but I cant find any blow out its running hot on that side as well could this be the valve?
66 HD
Yamaha 750 triple 78
riding on a GL1100 82
80 FXE
http://www.nakedgoldwings.com/gallery/HorseFly
jdvorchak
Re: Exhaust leak nose but no leak?
Post by jdvorchak »
It depends on the exact sound. An exhaust leak can sound like a loose valve. The first step I'd take, if I were you, would be to pull all four plugs and look at them. Then plug them back in but don't install them but let them lay on the head while you run a compression check. Wide Open Throttle while the compression test is in progress.
Running hot on one side usually means the other side isn't running. A plug reading should give you more info to base your diagnosis.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
