1985 GL1200 Limited, time for a new project.
bigscheaf
Re: 1985 GL1200 Limited, time for a new project.
#106
Post by bigscheaf »
Wolfie666 wrote:
bigscheaf wrote: That would be awesome! And no worries, I’m not a programmer by day either, but I can be dangerous.
I’ll have to dig on cb1100f.net and see if I can find the other post. Might be able to share some additional insight from the inline 4 side of the house. Should be fairly similar between the two platforms for the speedometer and tachometer.
there are 330 lines of code, if you PM me your email address I will send it to you.
Sounds pretty workable for what is being accomplished with the Arduino. And tweaking things like this are right up my alley. PM on the way.
1983 GL1100 viewtopic.php?f=16&t=67673#
1981 CB900F (Resto-mod Project)
1979 CB750F (Wiseco 823)
Wolfie666
#107
Post by Wolfie666 »
C5 Ignition is meant for the left cylinder head, but my FI engine has it on the right, so a little machining to the OEM housing to use for backplate...
Wolfie666
#108
Post by Wolfie666 »
Mounted...
Also made and mounted a 40A Circuit Breaker...
Rednaxs60
#109
Post by Rednaxs60 »
That is one good use for the old Gr/Gl cam (PG) sensor placement from the CFI system. Ready made and don't have to do too much work to use. Nice job.
Easter
#110
Post by Easter »
My ten gallon hat is off to you!
83 GL in process :IDTS:
Wolfie666
#111
Post by Wolfie666 »
Wiring the Denso Coils...
Rednaxs60
#112
Post by Rednaxs60 »
Good COP install. Can you provide more info on the COP units you selected?
Wolfie666
#113
Post by Wolfie666 »
Rednaxs60 wrote:Good COP install. Can you provide more info on the COP units you selected?
Sure,
2003 - 2006 Honda CBR600RR
Can get them on Ebay fairly inexpensive, and the harness usually comes with it,
but I prefer to make my own instead of cutting and splicing.
The connectors can be found there as well by searching for...
6 PACKS Pencil Coil Connectors Terminals For Honda CBR600RR/F4I Yamaha R1/R6
Wolfie666
#114
Post by Wolfie666 »
Finished!
Sort of...
Have to attend to a few details and iron out some bugs...
wingrider
#115
Post by wingrider »
Very nice!
Rednaxs60
#116
Post by Rednaxs60 »
Ditto! Very Nice
Sugs
#117
Post by Sugs »
And how loud are those pipes!
_______________________
'79 Honda GL1000 Goldwing
Buli
#118
Post by Buli »
Very nice. Look like pro job.
Kinde
Wolfie666
#119
Post by Wolfie666 »
Sugs wrote:And how loud are those pipes!
I have 12" steel baffles in them, and the Webers are louder, unless you really get on it,
so they are coming out!
Easter
#120
Post by Easter »
Very sharp ride. Good work. BOM material.
