https://ngwclub.com/forum/viewtopic.php ... 81#p828672
gl1000 - air cut off valve
Hi all - when disabling the air cut off valve i notice there are 2 openings under the valve; are both of these openings blocked off when disabling. thxs kenai
2 - 1979 GL1000
1 - 1978
1 - 1977
1 for parts
1 - 1978
1 - 1977
1 for parts
Re: gl1000 - air cut off valve
No.
Leave that normally open, pilot air circuit unimpeded.
Blocking just the vacuum source path (the small diameter hose) from the #1 carburetor hose barb fitting, to the air cut valve diaphragm assembly is all you need to do.
Cliff )
How well does it run with that disabled?
Won't make any appreciable difference in the way the engine runs with it disabled.
Mike Nixon's wisdom.
viewtopic.php?f=54&t=67126
Cliff )
- 1 Replies
- 2306 Views
Last post by gltriker
- 30 Replies
- 18443 Views
Last post by rcmatt007
- 0 Replies
- 313 Views
Last post by Mike-C
- 8 Replies
- 694 Views
Last post by Sidecar Bob
- 14 Replies
- 997 Views
Last post by ericheath
