Points - blue/yellow wire tabs / top or bottom
kenai
Post by kenai »
Hi all - checking some little things. The blue and yellow wires that go to points; do they go above or below the insulating washers; go on top side or bottom side of the attaching bolt? Tabs in towards each other or outward facing?..thxs kenai
2 - 1979 GL1000
1 - 1978
1 - 1977
1 for parts
Re: Points - blue/yellow wire tabs / top or bottom
it has been so long that I have done points..... I do know it can be on either side of the bolt, as my cb350t I had to swich it as it had a tendency to group out on the cover
tlbranth
Post by tlbranth »
It's tight in there. Just make sure the wires cannot contact ground and you'll be OK
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1975 GL1000
1970 CB750
