GP Style Clutch Lever, any good?
- 1983lux
Hey Guys,
I've been thinking about trying to improve the clutch pull on my '75. I find the clutch doesn't seem to be fully disengaged when I pull it in, making it hard to get it into neutral while the bike is running and sometimes causing the shifter to 'shudder' once in a while when shifting gears. If I reduce the freeplay in the clutch handle any more (not much there to begin with) by adjusting it down near the engine, then I find my hand gets so sore from reaching with the tips of my fingers and pulling it in traffic that I can't really put up with it. Also doesn't seem terribly safe if I needed to react quickly in an emergency.
I thought maybe replacing my clutch cable with a fresh one would help as I have no idea how old this one is. Also thought about switching the OEM style clutch lever to the GP style one on this page (scroll down a bit): https://www.partsnmore.com/parts/honda/ ... ng]=custom Has anyone tried one of these? Would it make my problem worse as maybe I couldn't pull the cable as far before the lever hits the grips?
Also would consider cutting off the old clutch perch, bypassing the clutch switch if needed, and replacing the perch/lever with an aftermarket unit that works really well if not too pricey. Any suggestions on reasonably priced perch/lever assemblies?
Any suggestions appreciated!
1975 Honda GL1000 - Naked
Motor from 1981 1100
1975 Cams and Carbs
Dyna S Ignition
1975 Cams and Carbs
Dyna S Ignition
Re: GP Style Clutch Lever, any good?
The later 1000's have a longer handle with a different throw. But the perch setup would have to be changed also. Usually the first question when discussing clutch operation is what type of oil are you using.
- 1983lux
Ah too bad, I used to have an engine-less '78 parts bike sitting in my yard, but somebody stole it! Wish I had've gotten the clutch lever/perch and driveshaft off of it first. I use Castrol 10W40 4-stroke motorcycle oil in it, comes in a white bottle. Correct me if I'm wrong but I don't think my clutch plates are the issue, as the problem is more with the clutch not fully disengaging, it doesn't slip or anything. If I adjust the clutch so that there is no free play in the clutch handle, it works better but then the clutch pull is just too hard and too long of a reach for stop/go traffic.
1975 Cams and Carbs
Dyna S Ignition
1975 Cams and Carbs
Dyna S Ignition
Difficulty finding neutral is often a indication of the oil not working properly with a wet clutch. Were it me I would try Honda oil or Shell Rotella just to see if there was a difference. Also one option is the 1200 hydraulic clutch conversion.
Me Too!!
October,2017 BOTM
October,2017 BOTM
I put the hydraulic system from an '84 1200 on mine. If you don't have 1200-style bars, the master cylinder will be sloped funny. I used one from a VF1100 or something. Very good feel and easier than the new cable I had before.
- 1983lux
Cool, thanks guys. I will try a different oil next time and see if that makes a difference. Will also see what changing the cable does, properly adjust the cable in the process, and maybe try either an aftermarket perch or buy a used 78-79 one and see how that feels. My current perch has the first few threads for the cable adjuster near the lever stripped so I can't really back it out any without it getting too wiggly. Maybe I'll see about a 1200 clutch if I ever have to pull the engine again.
1975 Cams and Carbs
Dyna S Ignition
1975 Cams and Carbs
Dyna S Ignition
You just change the clutch cover without removing the engine.
- flyday58
I tried a GP lever for the same reasons on my 76. Didn’t work because the GP is shorter, making the problem worse. A Honda oem cable and a longer lever from whichever ones had them helped quite a bit. Can’t tell you for sure because now I’ve heard it both ways on the longer levers (i.e., early vs later years).
2005 BMW R1200GS
2008 BMW R1200RT
1988 Honda XR600R
1974 Yamaha GT80
2008 BMW R1200RT
1988 Honda XR600R
1974 Yamaha GT80
- 1983lux
Ah, good to know the GP lever didn't work out, flyday. I'm pretty sure it's the 78/79 levers that are supposed to have a better pull.
1975 Cams and Carbs
Dyna S Ignition
1975 Cams and Carbs
Dyna S Ignition
