rear caliper piston removal
Rebuilding the rear brakes on my 78 I got the piston removed on the bleed niple side with a grease gun, how do I get the other one out?
- Goboy
- My Album: https://www.ngwclub.com/forum/viewtopic ... 30&t=60678
Re: rear caliper piston removal
I think I used air, split the caliper apart, then you should have access to fluid passage.
You're too small to ride a hog Billy!
Mike
1978 GL1000
Previous bikes: 05 Yamaha FJR 1300, 79 Suzuki GS 1000, 75 Yamaha XS 650, 73 Kawasaki S2 350
Mike
1978 GL1000
Pretty sure I used air for all my disassembly, been s while a d they weren't really crusty.
78 gl1000 rat project thingy...still under construction
76 gl1000 parts for 78? Trying to get running...
- Lucien Harpress
Air is usually sufficient unless there are REALLY wedged in there. Grease gun is definitely a "when all else fails" solution.
- ritalz
Clean the first piston up a bit and push it back in slightly. Put in a block to stop the first one and pump out the second one with more grease. Should be able to get them both out now for a full cleanup of the caliper. Works for me.
this ^^^
Project bike "Dixie" - 1986 GL1200 Aspencade being rebuilt from ground up to be a naked 'wing. Build progress thread here: viewtopic.php?f=30&t=71959
Build log video: View it here
BOTM November '22
BOTM November '22
The one is really stuck, tried a block of wood and some grease came free a little but pushed the other back in , gonna try a c clamp on the one that was out and try and force the other out
- 5 Replies
- 517 Views
- 26 Replies
- 1959 Views
Last post by pidjones
