Wog's '78 Wild Child build
pidjones
Re: Wog's '78 Wild Child build
#631
Post by pidjones »
Don't make the runners so big that you loose velocity in them.
#632
I'd be concerned how the sharp angles would affect flow. I'm not an engineer, but it seems to me that the exit from the carb and entrance into the head at such steep angles significantly affects the cross-sectional area.
wog
#633
Post by wog »
Both comments makes sense. With all of your feedback, I'll make it work. Just trying to make it unique, not just mount them on top of the heads. I like the stacks in the middle, and I have long legs. :IDTS:
#634
Track T 2411 wrote:I'd be concerned how the sharp angles would affect flow. I'm not an engineer, but it seems to me that the exit from the carb and entrance into the head at such steep angles significantly affects the cross-sectional area.
I was thinking the same thing. A more rounded exit entry would flow better. If you to kame the tube a little smaller I.D. at the entrance to the head that would help velocity some. Port matching everything would help too.
wog
#635
Post by wog »
Without cutting the frame, I can't get them inside, so I figured I'd buy Randakk's manifolds.
But here's my dilemma...
Do you guys that run them just get used to it and bring your knees out?
I'm pondering this...
The end angle would be a little different for each and one would be about a 1/4" longer.
#636
I think that version would work out best for knee room. I doubt the difference in runner length would make any significant impact on performance. My 2 cents...
wingrider
#637
Post by wingrider »
I find being shorter, (30” inseam) makes it so I don’t hit the stuff. :-D
Oldewing
Secretary
Secretary
#638
Post by Oldewing »
I am 6 3 and my knees hit enough it was a deal breaker.
Like the forward lean fix, looks cool.
#639
I contemplated moving them forward like that. It’s probably best. I recall others saying a good second gear shift and they smacked them. Subaru runners sweep down and then back up and down again. I’m assuming it’s to help with flow. Google them if you want them inside. I’m 5’10” and my carbs would hit easily with my left knee. They were smaller than Weber’s.
I think (what do I know??) the slanted ones would work well and give better throttle response.
wog
#640
Post by wog »
I'll play around with making the tubes a little shorter. That will also help with leg clearance.
There will be a fine line to not go too short and have the end's start to really oval out.
Are sync screws not needed because of individual air intakes?
I plan on making the manifolds out of steel as it matches the ID better than the alum.
wog
#641
Post by wog »
Just playing around, and won't go this route, but here's another way. Would need to make an interface for the carb bottoms and cut the two lower elbows and re-weld to the correct angle. But seems like it would work...
wog
#642
Post by wog »
Starting to merge my crazy ideas into something that might work.
Thinking of the front air filters having a beveled down shape so won't need rain covers??
And I might have posted this before, but the intakes can handle the 400 degree heat for powder coating. :IDTS:
wog
#643
Post by wog »
More progress...
My knees clear the back of the carbs by an inch or so.
I know it looks like a long distance between the carbs and the heads, but still much closer then the old setup.
I'll use this (that I rarely use) to get both sides ground parallel.
#644
:2thumbs :2thumbs
wog
#645
Post by wog »
Got to redo this side and shorten the rear tube a bit to get it even,
then make the right side, but moving along... :crosso
