VW carb switch, 34 to 30
ob1quixote
Re: VW carb switch, 34 to 30
Through the top. Best to do some research, lots of info at thesamba.com forums
1979 GL1000
2001 DRZ400
1983 CR480
2001 DRZ400
1983 CR480
- bbuice
Thanks. Have not heard of that sight.
1975 GL1000
2003 GL1800
1975 GL1000
2003 GL1800
ob1quixote
Fuel flow diagrams help with understanding how the Solex carbs work. The 34 is different from the 30, but not by much.
1979 GL1000
2001 DRZ400
1983 CR480
2001 DRZ400
1983 CR480
- bbuice
Thought I would check back in and give an update. I sent the 34PICT-3 carb back and got a 30PICT-1. Installed it and the bike cranks and runs. I even have it idling although it is pretty rough. So, I am going to take it back off and clean/blow it out and put in the size jets that ob1quixote has in his and see how that goes. Just waiting for the jets to come in. So, progress has been made. Thanks for everyone's comments and advice. More as it develops. Benny
1975 GL1000
2003 GL1800
1975 GL1000
2003 GL1800
ob1quixote
Just for your knowledge, I'm as just above sea level. My motor is tight, getting 180 lbs of compression on all 4 cylinders. Might want to keep that in mind, your best result could be something different.
1979 GL1000
2001 DRZ400
1983 CR480
2001 DRZ400
1983 CR480
- bbuice
Gotcha. Thanks.
1975 GL1000
2003 GL1800
1975 GL1000
2003 GL1800
- bbuice
I installed the 30 PICT-1 on the bike and it fired right up and I was able to get it to idle but not really well. I set the idle speed to about 1100-1200 rpm and made the adjustment to get the best idle. However, it doesn't settle into a smooth idle but kind of oscillates up & down between 1050 & 1300 rpm. What would be the cause of this? Jets maybe? I have no clue what size jets are in it. They aren't marked. Any pointers would be appreciated. Benny
1975 GL1000
2003 GL1800
1975 GL1000
2003 GL1800
ob1quixote
Did you set the idle by adjusting the 2 carb "jet screws" on the side? or the choke knock down screw?
1979 GL1000
2001 DRZ400
1983 CR480
2001 DRZ400
1983 CR480
- bbuice
The 30 PICT-1 only has one screw. It is simpler than the PICT-3. After reading some of the stuff on the samba.com I went with it. I am going to pull it off and clean it and blow it out. I’ll probably wait for the jets I ordered to come in but that will probably be early August.
1975 GL1000
2003 GL1800
1975 GL1000
2003 GL1800
- bbuice
Any idea if there is a way to tell what size a jet is that isn't marked? Is there a tool to figure it out? None of the jets in this Chinese carb are marked. Benny
1975 GL1000
2003 GL1800
1975 GL1000
2003 GL1800
Re: How to Identify Jet Sizes?
There is. You should be able to find them on Amazon or ebay, or a local supplier to machinests. Search for pin gauge or jet gauge. You might get a local shop to use their gauges to tell you what you have.
- bbuice
I have some jets now. I am rusty on idle characteristics. If the bike is has sort of an oscillating idle, not a steady speed. Would that generally indicate a lean mixture? If so then I should go up on the idle jet size, yes?
1975 GL1000
2003 GL1800
1975 GL1000
2003 GL1800
ob1quixote
Your 30 is very different from my 30, enough that I don't know what to suggest.
1979 GL1000
2001 DRZ400
1983 CR480
2001 DRZ400
1983 CR480
ob1quixote
Ran into a friend who took video on my first interstate trip. This was when I was running the 34, switched later to a 30.
34 didnt like altitude changes, 30 ended up being "set it and forget it"
https://vimeo.com/503023056
1979 GL1000
2001 DRZ400
1983 CR480
2001 DRZ400
1983 CR480
