Hey All,
just put new seals in my carbs. It started and ran but started to leak fuel from #4 and lower the idle. then turn the gas off and it stopped leaking and then the idle raised up and ran more normal. Me and guy next door are thinking the needle and seat are the culprit. I'm going to try and put in a used needle and seat and see if that fixes it. If not I will be swapping my LTD carbs and cross my fingers there not clogged. If that doesn't work I will be bringing up the van.
Paul
75 carb leaking
- GL1-242
75 carb leaking
84 GL1200 STD
75 GL1000 #202
75 GL1000 (AKA, GL1-242)(AKA, Flipper)
76 LTD
76/77 CB750F
Bultaco's = 121, 152, 167, 188
75 GL1000 #202
76 LTD
76/77 CB750F
- GL1-242
Re: 75 carb leaking
looks like it cleared up and not leaking. turned gas on and idle didn't change.
Paul
Paul
84 GL1200 STD
75 GL1000 #202
76 LTD
76/77 CB750F
75 GL1000 #202
76 LTD
76/77 CB750F
Re: 75 carb leaking
The next time you do a rebuild, hook up a bottle of 91% isopropyl alcohol to it and let it set overnight to check for leaks.
- GL1-242
Re: 75 carb leaking
So before installing the carbs on bike just connect a makeshift tank and fill with the alcohol. Let it gravity feed into carbs.
Paul
84 GL1200 STD
75 GL1000 #202
76 LTD
76/77 CB750F
75 GL1000 #202
76 LTD
76/77 CB750F
- skydog
Re: 75 carb leaking
Hey Paul ,had to work the late shift,give ya a call later today.
75 naked "Blue Streak" gone
78 fairing bags "Brownie" 4 sale
80 standard project 4 sale
84 Standard, Vetter bags "Horse with no name"
85 Interstate gone
84 aspy
86 aspy
"When the day comes to settle down,who's to blame if you're not around?You took the long way home"
85 Interstate gone
84 aspy
86 aspy
- 8 Replies
- 825 Views
Last post by Big_Blumpkin
- 11 Replies
- 762 Views
Last post by vb_GL1000
- 7 Replies
- 432 Views
Last post by jml74
- 14 Replies
- 479 Views
Last post by Shadowjack
- 14 Replies
- 1082 Views
Last post by crazylarry
