Bike WAS running perfect till sunday :/ ...running cold
Moderators: CYBORG, robin1731, Oldewing, Forum Moderators
rusty wing
Post by rusty wing »
My '76 has been running better than ever. I rebuilt the carbs and used the mercury sticks on 'em.
Idle has been perfect. ok, now for the bad....the bike will only get warm at all at idle, runs cold all the time. I went on a long ride Saturday w/ a friend and it performed great. Then....Sunday on the way back from work thru Atlanta, the bike starts loosing power....70mph tops.
Havent looked at it yet, but I think the bike is running too rich (runs cold) and maybe the plugs are starting to foul?
How am I supposed to set the air screws?
I am unsure where to start, just looking for some feedback.
Thanks,
Rusty
Toehead
Re: Bike WAS running perfect till sunday :/ ...running cold
Post by Toehead »
Thermostat stuck open could explain the cold running, but probably not the loss of power.
Is it running rough, like you are down a cylinder or two?
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
rusty wing
after looking at some posts....
i have set my idle screws out 1 1/2 turns out....
is that rich or lean?
That is probably a bit lean for a 76. Run it for a bit then check the plugs to be sure. If you can the idle drop procedure is a pretty fail safe way to set the screws.
wilf
Post by wilf »
possily fuel supply problems or electric gremlin's. there are a ton of things that can cause your problem and you just have to work your way throw it.
I think on the radkin site there are some good writeups on where to start your systematic overhaul of your bikes systems. dirty fuel tank blocked fuel cap vent plugged fuel filter weak fuel pump sticking slides on carbs etc.
weak or cracked coils. problems with the points condensers . bad spark pug wires or boot's. There are 5000 ohm resistors in the sparkplug boots along with a spring. these can become brittle and coroded and cause loss of spark.
79 naked wing - not so naked anymore
80 interstate project very naked now
90 1500 heartbreaker
RB
Post by RB »
Run the bike..while running spray some water on the header pipes..water should steam off instantly..if not there's your non firing cylinder(s). If 1/2 or 3/4 coil/point issues if just one then most likely carbs issues.
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her :(((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
rusty wing
Thanks guys...i know where i am going to start.
rusty wing
Well, after sticking new plugs in, the bike is back to running like a charm. Also, I see that the temp guage sensor has come off (hence running cold all of a sudden).
Today, riding to work, I stalled it at a green light....then wont start, so I roll stated it to make it to work.
After I parked it, I tried to start it again...NOTHING.
So, I hope I make it back home.
Guess its time to start overhauling to ignition parts.....stators are uncommon to go out on these, right?
Thanks
Oldewing
Secretary
Secretary
Post by Oldewing »
yea, the 1200 have had some problems. Check the 3 yellow wire plug under the left side(battery) side cover for a good connection. Most cut that plug out and hard wire it, any yellow to any other yellow is good. Shoptalk has the complete run down on how to check your stator.
82 GL1100 Interstate-Oldewing (under going work, fresh frame, NEW motor)
68 CB 350 Hiding in my shed, soon my darling soon........
06 GL1800 daily rider
83 QR 50 Wifeys bike
You say it didn't start. Did it turn over and just not start or did it not even turn over? I'm a bit confused because you talk about ignition parts then ask about the stator.
Like Oldewing said check the plug at the stator. The plug is a kind of known problem from corrosion. And most of us have just wired them.
rusty wing
Well, the bike had no electrical juice, which is why it wouldnt start. These bikes are OK running with no battery? I will test it when I head home in a bit. I still have the kick start bar :)
I will most definately check that plug. I have never had a problem with the charging system before, but the bike does sit more than normal during the winter.
pidjones
Post by pidjones »
It would be difficult if not impossible to start without a battery. You would at a minimum need to temporarily jumper the ballast resistor - tough to do if you haven't set up for that previously. And riding without the battery will be hard on the electrical system. Might just be a dead battery - they do die, you know. Then there is the "three yellow wires" connector that is marginally designed (although they did last 30-40 years), are not listed in the manual for service, and live in an area of moisture and battery acid fumes. If the problem is just the battery, NOW would be a good time to replace the connector. Many threads on doing this. I use high current RC helicopter connectors covered by shrink wrap. Some just solder the wires together (no polarity issues as it is AC) and shrink wrap.
1972 Triumph T150V Trident rescue - in sad shape
;) 9+years since last post
Good information, though! tumb2
pidjones
Post by pidjones »
gltriker wrote: Wed Sep 22, 2021 7:39 am ;) 9+years since last post
Why did it show up in my unread feed?
Figor
Post by Figor »
On a different forum I have been getting old replies in my new emails. When I questioned it I was told it was some form of phishing attempt. Maybe that’s what’s happening?
1981 Goldwing GL1100
Microsquirt efi
