Leaking Carb's
- Bohdan
Leaking Carb's
Greetings Gents,
I have reviewed the issues everybody has on GL1000 bikes (GL1100 carbs actually) with regard to leaking. Mine naturally leaked apparently on through the float bowl seating. Could tell because of the yellow stains from the gas. SOmebody suggested to maybe bang on the float bowls and maybe that would make them work again. I did that and lo and behold, it stopped leaking. The question I have is this a band-aid repair? or would this happen again? and if so, would the float bowls need to be re-adjusted? Mighty obliged.
'77 GL1000 Blue
'77 GL1000 Botina
'77 GL1000 Roadkill
93 GL1500 Big Red
13 GL1800 Nepper
'77 GL1000 Botina
'77 GL1000 Roadkill
93 GL1500 Big Red
13 GL1800 Nepper
- wingrider
Re: Leaking Carb's
Banging on them and stopping the leak meant that the needle was staying open for some reason. Perhaps some speck of something in the seat, or the float was just stuck. It may not do it again, but if it does, I would pull the carbs off and do some inspection to see what might be causing your issue.
Re: Leaking Carb's
We have been banging on carbs since the dawn of time, you should be fine.
- Bohdan
Re: Leaking Carb's
Thanks Gents, Mighty obliged.
'77 GL1000 Blue
'77 GL1000 Botina
'77 GL1000 Roadkill
93 GL1500 Big Red
13 GL1800 Nepper
'77 GL1000 Botina
'77 GL1000 Roadkill
93 GL1500 Big Red
13 GL1800 Nepper
- desertrefugee
Re: Leaking Carb's
Why yes, we have! My preferred method is a 3/8 extension rapped with the butt of a screwdriver.
- wingrider
Re: Leaking Carb's
I gave a chinesium 4 wheeler to my niece and nephew for Christmas a couple years ago….carb was gummed up when I got ahold of it. Cleaned it like q well used whistle, and the darn thing started leaking…figured float is stuck somehow, started banging on it, and figured it would break before the darn thing stopped leaking. Still haven’t gotten time to fix it.desertrefugee wrote: ↑Mon Oct 11, 2021 5:15 pm
Re: Leaking Carb's
Personally, once the float is unstuck I’d run some carb cleaner like Lucas through it for a couple of tanks. Good chance things are just varnished up.
- NotSoLilCrippseys
Re: Leaking Carb's
Agreed. I use Seafoam, likely because I have used it with success. Other products also work. You may need to pull the carbs if the issue keeps resurfacing, but maybe you can put it off for a good while. And you might change out the fuel filter.
In the Stable and Ridable
1978 CB550K - son's cafe
Sold
Sold
Re: Leaking Carb's
Where was it leaking from? I have a similar issue after re-installing the engine and the leak seems to be coming only from the right side and from where the fuel lines run in the right rear and front carb. I tried banging on it and it didn't seem to do anything.
- 4 Replies
- 459 Views
Last post by skydog
- 11 Replies
- 762 Views
Last post by vb_GL1000
- 7 Replies
- 432 Views
Last post by jml74
- 14 Replies
- 479 Views
Last post by Shadowjack
- 14 Replies
- 1082 Views
Last post by crazylarry
