"Parts Bike" a '77 rebuild thread
robbie202
Re: "Parts Bike" a '77 rebuild thread
#61
Post by robbie202 »
https://imgur.com/a/DMIWOq4
Valves and belts done.
5 second video
'77 GL1000
'03 Sportster
2020 KLX 250
sparkyrasmus
#62
Post by sparkyrasmus »
I see from the video that you have gone with a twin carb setup. Can you show some more pics?
1978 GL1000 - almost stock SOLD
1979 GL1000 - Winter project/parts bike - custom "Busted" STILL BUSTED
And the newest acquisition, 1979 Yamaha XS 650F to be a sidecar tug. crossy.gif
robbie202
#63
Post by robbie202 »
sparkyrasmus wrote: Wed Jun 15, 2022 4:18 pm I see from the video that you have gone with a twin carb setup. Can you show some more pics?
yes i will post some as soon as i have something new to add. planning on using a dual-pull setup.
'77 GL1000
'03 Sportster
2020 KLX 250
robbie202
#64
Post by robbie202 »
shakehands
'77 GL1000
'03 Sportster
2020 KLX 250
robbie202
#65
Post by robbie202 »
Ok where do i connect these last 2 wires?
'77 GL1000
'03 Sportster
2020 KLX 250
robbie202
#66
Post by robbie202 »
12v Power comes from the circuit on the new control unit which i drew in purple. There's no kill switch wires and no wht/grn as in the dyna instructions.
Do i connect the red wire (from dyna s) to the purple wire (12v from motogadget) and the other 2 contacts on the coil all together? I don't understand the path of the electricity.
'77 GL1000
'03 Sportster
2020 KLX 250
robbie202
#67
Post by robbie202 »
Ok i think this is it
'77 GL1000
'03 Sportster
2020 KLX 250
#68
Looks pretty good to me. Just some thoughts..... Are you going to have any safety interlocks for starting? Clutch/ Neutral light? Also is the key going to kill power out to the coils through the M Unit? If I read this right Solenoid Terminal 1 will be hot all the time and according to your little note 5 and 6 will as well. Is there any issue with having the Reg /Rec getting power from Term 6, 24/7/365 or should that be switched? I believe in the OEM Setup the rectifier has a hot lead all the time but the regulator is switched. I do not know if the Ricks Reg/Rec is setup up for that?
robbie202
#69
Post by robbie202 »
that's a good question about the constant power going to the reg/rec i had not thought about that but it looks correct from the diagram provided by revival cycles
https://revivalcycles.com/blogs/technic ... ring-guide
the diagram i posted is just what is needed to start the engine. will add the lights later as i go along.
'77 GL1000
'03 Sportster
2020 KLX 250
robbie202
#70
Post by robbie202 »
no start today but i pushed the button!
'77 GL1000
'03 Sportster
2020 KLX 250
robbie202
#71
Post by robbie202 »
Re did the timing and it started!
Ten second video with sound here https://imgur.com/a/Su8skUW
Got it running. not well but its running! this bike was parked from 1995 until today.
something obviously wrong but i don't know what.
so what is that awful high pitched rattling sound???
what do i check first?
'77 GL1000
'03 Sportster
2020 KLX 250
Chainman
#72
Post by Chainman »
action1 nice :8)
1975 GL1000
#73
Progress!!! I can not hear the noise you are referring to but one of the funky things I have found in the past is over tensioning of the timing belts. Make sure that you do not "assist" the tension set by the springs.
robbie202
#74
Post by robbie202 »
Belts don't seem overly tight. Really can't place where its coming from i hope its not serious.
'77 GL1000
'03 Sportster
2020 KLX 250
#75
Could get serious quickly with a water pump ceramic seal not being immersed in coolant while the engine is running 🤔
