Post#10
Hi Dave! - and whoever else additionally Reads, Understands and Follows my Instructions.
Turn the carburetors *rack* upside down, with all 4 float bowls removed. see attached photos and
VIDEO
If you have a carburetor Pressure Tester air pump, a Sphygmomanometer, ( even a turkey baster bulb per Dave ) handy, attach its rubber hose to the *rack* fuel inlet hose barb fitting and squeeze the air pump plunger or rubber bulb to pressure test the sealing integrity of all 4 float valves in one fell swoop.
Utilizing a vacuum pump doesn't cut it for accuracy when leak testing a normally very low pressurized carburetor float valve needle and seat.
When the inverted *rack* is pressurized as I have directed, and all 4 float valve needles and seat combos are working correctly together, they should not allow less than 7psi air pressure to blow-by; the oring which seals the OD of the brass seat with the carburetor bòdy will be verified, too. NOTE: This is presuming the plenum seal AND all 4 plenum-to- carb seals are intact,too !
note: 7psi is a reasonable minimum number based upon my many years pressure testing diaphragm type carburetors.
I offer up that suggestion because it revealed the cause of a very small float valve needle leakage situation present when I pressure tested a GL1000 "rack"; exactly same as I have presented the process in this post.
Tests All the various sealing components up to each of the 4 float valves.
(in addition to the 4 individual float valve sets' sealing integrity, the Plenum seal, and all 4 plenum -to- carburetor flange D rings are verified, as well )
Prior to this unique testing session, I had utilized a McCulloch carburetor pressure testing tool I had acquired in the early 70s, until I wore out its rubber bulb.
To remedy the worn out McCulloch tool situation, I eventually purchased a miniature version of a carburetor Pressure Tester Pump Assembly from an Amazon listing several years ago, It's the green anodized air pressure pump with 0-30psi pressure gauge pictured in both photographs and VIDEO, too.
Yes, 25psi is
extremely excessive. I absolutely had to see, though, how much applied air pressure the "rack" would resist.
Look at the gauge..25psi and it held there .
When I lifted a float to release that extreme pressure
PFISST!!
, the tester's gauge needle rapidly dinged the 0psi stop and now reads ~5psi. c'est la vie
AGAIN -watch the VIDEO. The link is immediately below this photograph.
vvvvvvvv VIDEO vvvvvvvv
[size=150]20201109_090246_2226467060246 (1).mp4[/size]
Watch My *Rack* Pressure Testing Video
up there
"Can't see the paint when your looking thru the handlebars..........." -
Oldewing
"I'd rather Ride than Shine" -
RAT
Me Too!!
'75 GL1000 home built trike;
http://www.ngwclub.com/forum/viewtopic.php?f=30&t=39996
October,2017 BOTM
