'77 Wing "Forever Bike"
Re: '77 Wing "Forever Bike"
#181
Well, either the short ones or custom long ones that lean forward.
wannabridin
#182
Post by wannabridin »
ya, i'm playing around with some options. gotta get it running first :-D
#183
ah to have legs so long that my knees hit something
wannabridin
#184
Got the fuel lines laid out, need to finalize them. Have to figure out return springs & throttle cable holders next.
Changed the tail light. Rear turn signals will be some high power led bolts on the license plate holder, will function as brake lights too w/ a modulator. The tail light bulb was upgraded to a brighter LED w/ a flasher too.
wannabridin
#185
Got a 1/4 turn throttle tube from Murray's Carbs in as well as a longer travel cable splitter from Venhill. The shorter one wouldn't quite allow for full carb opening, but now I should be good to go.
Ordered a NOCO lithium battery (I have a modern MOFSET R/R installed too), it's about 1/3 the size of the one that was in there. Need to figure out how to secure it and what to do with all the new space for activities around it :-D
Installed a priming button in place of the stock choke knob, which is basically a bypass for the oil pressure switch. Found the tip from a forum member, but can't remember who.
Fuel lines and throttle cables will be finalized soon! Hopefully can test fire shortly after. Probably need to drain the fuel and re-fill with fresh!! Then, finish up the rear lighting and go test ride! Hopefully there's only minimum tuning gremlins!!
#186
Do not forget the knee guard. Do not want to see smile scars on your caps.
wannabridin
#187
:happy_251: :happy_251: :happy_251:
wannabridin
#188
Throttle cables finished and working well. Had a little oopsie when i fired it up yesterday - i had forgot the oil galley plug for the oil pressure gauge (ironic huh??) so i lost about a quart of oil out that back hole in just a few seconds! I guess my oil pressure test was successful!
Bike fired quickly once the fuel system was primed and the accelerator pumps were active. Took about 2 hours last night to clean up the mess and it's still not done.
Hopefully get to test fire it again today! Need to let it warm up so i can get idle mixture, idle speed and sync done. :-D
#189
So close and yet so far. The wrenching is much better than the clean up. But pretty much par for the course.
wannabridin
#190
wannabridin
#191
Nearly ready to rip
#192
Wow, looking mean.
ritalz
#193
Post by ritalz »
Dual Webers and four into four is a great look.
digger
#194
Post by digger »
1975 GL1000
#195
Can we get a right side shot (pic)? About to mount my fuel pump and would like to see yours from the side.
