Upper radiator hose was relatively easy to change, to change the lower hose I also had to remove the housing for the waterpump.
Replaced lever assys and had steel braided hoses that I also changed at the same time.
Did not check them before but apparently they are made to go straight to the master cylinder, but even then they seem a bit long. Tried to route them a lot of different places before giving up. Will probably need to get brake hoses made to fit.
Also got a chance to try out more of the electronics since I wired up the brake switch(wich is needed for the setup of the electronic box).
Glad to see that hi/lo beam and also the hi beam light in the dash were working good. I know since last time that the lamps for the indicators are not working in the dash. Will have to work out why some other time.
My 3in1 rear lights do not really fit so good in the old Honda frame.
There is m8 joint that could fix it but it is 11mm in diameter and the hole is 10mm, so will probably end up drilling the frame out.
