![Image](http://www.ngwclub.com/gallery3/var/resizes/wingmans/roncarGL/keymaker/tools.gif?m=1407595185)
Keys for vintage Goldwings cut by code (and numerous other Honda's that use the same key blanks) 5 number, 3 number, and A00-D99. I can also cut keys for aftermarket ignitions that use H00-H99 codes. (Most aftermarket ignitions do not have the code on the lock, only on an original key.)
**NOTE** If lock or key has been altered, the code may not work.
If you have a working key and no code, I MAY still be able to help.
PM or email me at codecutkeys@gmail.com .
Available blanks, subject to change based on availability.
For 5 number codes (75 and 76 only. Brass or nickel plated.)
![Image](http://www.ngwclub.com/gallery3/var/resizes/wingmans/roncarGL/keymaker/72-73.jpg)
for 3 number and A00-D99 (77+)
![Image](http://www.ngwclub.com/gallery3/var/resizes/wingmans/roncarGL/keymaker/keyblanks.jpg)
Here are a few locations of the key codes.
A 75 or 76 ignition lock code 77890.
![Image](http://www.ngwclub.com/gallery/d/143075-1/codeign7576.jpg)
A 75 or 76 helmet lock code 29087.
A 77-82? ignition lock code 117.
A 78 or 79 Shelter cover code 508.
A GL1100 trunk lock code 616.
A 82-83 GL1100 saddlebag code A31.
![Image](http://www.ngwclub.com/gallery/d/143081-1/codesaddlebag.jpg)
A GL1100 cover code 314.
A GL650I luggage lock code 813
![Image](http://www.ngwclub.com/gallery3/var/resizes/wingmans/roncarGL/keymaker/GL650Luggage_813.jpg)
