1978 Gl1000 float valve
Jonesz
Post by Jonesz »
Hi all. Been awhile since I needed help but am wondering. I have a leak #1 carb that I suspect is due to needle valve seat issues. If I tap the carb with a mallet and wooden dowel the leak often quits only to resurface the next time I fire the bike up. I intend to pull the carbs and reinstall new valves and bowl gaskets. When I check partzilla they show two different parts #s for that item 16011-371-014 or 16011-371-305 in both cases four are required. Any of the gurus here know which part # is the correct one? I am a long way out in the boonies and don't want to order the incorrect ones or maybe it is just an update? Also the gasket set is unavailable anyone have a satisfactory supplier? Any advice appreciated. The bike runs strong after a thorough cleaning two years ago and therefore will not be ordering a complete rebuild kit.
Jonesz
1979 Suzuki GS850. Sold
Re: 1978 Gl1000 float valve
-014 was superseded by -305 according to Service honda
Jonesz
Post by Jonesz »
Thanks Whisker. Much appreciated. Anybody with a Canadian supplier of float bowl gaskets?
Jonesz
and... Here's the total contents of the Float Valve Set
*yes, the filter screen, too*
Cliff ;) )
Jonesz
Post by Jonesz »
Thanks Gltriker nice to see a new screen element
Jonesz
You are Welcome, Jonesz 😎
Cliff ;) )
redglbx
Post by redglbx »
Jones’s, just order a a seal set from Randakks, they use Viton which better stands up to the alcohol and other additives in todays fuels.
NotSoLilCrippseys
Post by NotSoLilCrippseys »
I'm not all that knowledgeable, but I'm not sure why dowel/mallet on a running motor with a needle valve problem would correct matters for the ride. I think of that approach as more of a remedy for the occasional hanging float? (I've used it many times.) I'd probably first suspect that the float pin is binding or if there's something keeping the float from rising enough to seat the valve.
In the Stable and Ridable
1978 CB550K - son's cafe
Sold
https://www.randakksblog.com/floats-101/#more-936
Scroll down through this :oldies Randakk's tech blog article to Float Alignment / Prep and its photographic examples of correct vs incorrect float assembly appearances.
in that Tech Blog section, Randakk states... " you should check each float carefully to make sure that it is square, plumb and that the pivot is true"
for Best results, Read the entire article ;)
Cliff ;) )
