Fan Temperature Switch
OhioBill
My Album: http://www.ngwclub.com/gallery/v/wingmans/OhioBill
Post by OhioBill »
Has anyone tried a Beck/ Arnley 2010817 switch. Physically it looks the same as a Honda switch and the best I can tell the operating range is 195 to 210.
OhioBill
Retired and Loving it.
1979 Black (to be restored)
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
Re: Fan Temperature Switch
Never tried it but the temperature is correct and Beck/Arnley is a good company. Should work fine.
OhioBill
Post by OhioBill »
Turns out the threads were too small.
OhioBill
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
Lucien Harpress
Post by Lucien Harpress »
Speaking of which, what is the stock temperature range for the GL1000, since we got the thread started? I'm going to have to check this for myself sooner than later and can't recall what it is offhand.
redglbx
Post by redglbx »
Bill, did you by chance look at thread adapters ?
OhioBill
Post by OhioBill »
No, but I think that would be a viable way to go.
OhioBill
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
IIRC, similar thermo switches are made in 16mm and 18mm threads. The GoldWing rads require the 18mm version (CX/GL500/650 bikes' rads require the 16mm version).
Some similar switches are rated as low as 5A and others as high as 30A and a relay is recommended (per several threads on this forum) if you use one of the ones with low current ratings (including the Beck-Arnley) (2011614 should be the correct number).
FWIW, the one I'm using cost about $10 on eBay a few years ago. For that price I added a "parade switch" so that I could turn it on manually if the engine got hot and the thermo switch didn't turn the fan on.
OhioBill
Post by OhioBill »
I also added a parade switch so I won't be stranded if the fan sensor ever fails.
OhioBill
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
I like to add an indicator light for the fan too; I've used LEDs both times I've done that and the first time I was surprised to see the LED lighting up at speeds above 80 Km/h at night. I figured out that the wind was turning the fan enough that it generated a couple of volts ;)
Lucien Harpress wrote: Thu Oct 17, 2024 5:26 pm Speaking of which, what is the stock temperature range for the GL1000, since we got the thread started? I'm going to have to check this for myself sooner than later and can't recall what it is offhand.
viewtopic.php?p=820983#p820983
Cliff ;) )
The 201-164 requires a special connector that is differernt then the early wings
Lucien Harpress
Thank you sir!
tlbranth
Post by tlbranth »
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1975 GL1000
1970 CB750
