Leak down tester recommendations
jimbonaut
Post by jimbonaut »
Thinking I might need one. Don’t have a ton of money to drop on the thing. Any suggestions?
dontwantapickle
Re: Leak down tester recommendations
Post by dontwantapickle »
Poor man's leak down test:
1. Remove the valve cover and make sure that both valves are closed on the cylinder to be tested.
(wiggle the rockers to verify the valves are closed.)
2. Remove radiator cap and oil fill plug.
3. Remove the spark plug and use a compressor to pump air into the cylinder.
4. Listen for air leaks.
if you hear air in the carb, intake valve leaking
If you hear air in the exhaust, exhaust valve leaking.
If you hear air in the oil fill hole, rings are leaking.
If you see bubbles in the radiator, head gasket is leaking.
Try it.
It's always worked for me.
Oldewing
Secretary
Secretary
Post by Oldewing »
I shagged a 31.00 china one off Amazon, works well enough for me..
redglbx
Post by redglbx »
Don, great tip ! 👍
I'd add that it is normal to hear some air leaking past the rings in a cold engine because of the ring end gaps, which should close when the engine is at operating temperature.
dontwantapickle wrote: Sun Dec 08, 2024 1:03 am Poor man's leak down test:
Try it.
Great tip..... unfortunately my hearing is so bad I can honestly ignore my wife! anim-cheers1
redglbx
Post by redglbx »
Rodger,, 😁😁😁😁👍👍👍
