Stator plug replacment done right
- technojock
- Brass Member
I replaced the stator plug on my wing and documented the process on the following page.
http://www.oregonmotorcycleparts.com/GWstatorplug.html
I will be adding more info on cleaning, repairing and replacing connections as I get to it.
Tony
Tony
Old enough to know better but to crazy to care.
nice job.
- Cookie
- RIP: 1950-2011
- technojock
- Brass Member
- Cookie
- RIP: 1950-2011
- technojock
- Brass Member
- Cookie
- RIP: 1950-2011
The one on the yellow bike mostly cleaned up with a few replacement sections. On my red bike there is not much hope for the stock harness, which is fine since I intend to modify it.
- technojock
- Brass Member
Let me know it you have any problems with it. I make repair harness sections on custom order. Like with the plug cleaning and repair, I've been meaning to do a page on this for a long time...
BTW, I replaced the rectifier plug and added it to the bottom of the page with the stator plug. Later on I will do a page showing the repair of a few different plugs. I think I'm done documenting the replacement of plugs for a while.
Tony
Tony
- mooseheadm5
I guess you did not know the "old bus mechanic" Cookie was referring to is none other than Cookie himself
-P
[b][color=blue][url=http://www.ladyada.net/learn/multimeter/]Learn to use a Multimeter, Click here![/url][/color][/b]
-P
- Cookie
- RIP: 1950-2011
Yep, they are a bit simpler to wire than a Greyhound or train.
I like wiring a lot better than most of the other tasks. I've got to pull the oil pan off my Chang soon which should involve oil falling in my face. I'm not looking forward to that at all but better to cure leaks before the riding season.
I probably should pull one jug too as I have a small leak there also.
- technojock
- Brass Member
Cookie, are you the guy that contacted me about making parts for a Chang Jiang? It's an interesting beast but I never did get the info from the dealer that was supposed to help with the project.
I imagine that wiring a truck or bus wouldn't be any easier that on a bike. Sure the wires are larger but you don't have to stand on your head to get to the weird places on a bike. One reason I never liked working on cars and trucks is all the crawling around underneath always turned me off.
Tony
Tony
- Cookie
- RIP: 1950-2011
It might have been possible Tony that I contacted you about Chang parts but I don't recall it just now. What was the part? There was somebody in the Pacific NW that offered to make me fork bushings last year but I got a set in Denver.
It was actually a Chang guy named Dan who sent me to this site when I said that I was thinking of making an early Goldwing sidecar tug.
- technojock
- Brass Member
- Cookie
- RIP: 1950-2011
- technojock
- Brass Member
It's hard to say. I do know that a stator has more internal heat when the connector is corroded but I don't know of a 4 cylinder wing that hasn't corroded the connectors...Cookie wrote:Why do you think there is so much for stator problems on these? Is it just the corrosion on the connectors or too small a unit for the load?
Other bikes will knock out a stator from time to time with good connections so it could just be that we are seeing the normal failure rate.
Tony
