Hopefully it wont take too long to get here so I can get this thing on the road! I am ready to ride it!
78 Blue Baron
- CFD132
Re: 78 Blue Baron
Well, the old system is shot.
I am about to order a new one and I have decided to go with the complete system.
I guess you could say that I am too far into this now to turn back!
1978 Honda GL1000 (Current Barn Build Project)
2008 Victory Vision Tour
- CFD132
Re: 78 Blue Baron
Here is a quick run down on the low down on what I have done to check;
Cleaned and sanded all connections in the wiring harness to ensure a good connection.
I have check the wiring diagram in the manual to make sure everything is connected as it should be.
I have a old DynaTech system and I have contacted the tech support and they have given me the wiring diagram for that system.
I am almost to the point of pulling the trigger on a new DynaTech System,
Thanks Guys & Gals for the help. You have been awesome and spot on so far, lets see if we can do it again.
- oldwings 78
Re: 78 Blue Baron
Might sound crazy but have you checked and cleaned your ground connections?
Terry
Terry
"A man who is good at making excuses is rarely good at anything else" Benjamin Franklin
"A man who will sacrifice freedom for security deserves neither" Benjamin Franklin
'78s are the best looking GLs Just ask Doc
Re: 78 Blue Baron
+1 on the crazy things: Are you absolutely sure that the battery is at 100%?
- CFD132
Re: 78 Blue Baron
Good thoughts. I have a new battery that was charged 24 hours before the install. I will double check the ground since I had a issue with it when I reinstalled the ground cable.
Oldwingguy
Re: 78 Blue Baron
I had the same no spark on my 76 after doing some work on the carbs. My system is the older
Dyna with the black box. There should be a ground wire for the box itself. If that is not grounded,
no sparky.
no sparky.
- CFD132
Re: 78 Blue Baron
Thank you for your suggestions. I have checked all of the above with no success. Things have been on hold as I am trying to get some money together to finish this little project up. I am going tomorrow to purchase a donor bike. It has a Dyna System that has never been installed. If all goes well, I will have my next project sitting in the corner when this one is complete! I don’t need a lot to get this one going now, and I can pick up the parts I pull off the donor as I get more working budget. Who knows, maybe a his and hers when I am done. I will post photos of the donor (which is blue) when I pick it up tomorrow!
- CFD132
Re: 78 Blue Baron
I picked up the donor bike tonight for $500.00. I am posting a few photos then getting on the computer...
- CFD132
Re: 78 Blue Baron
Now I have hit the jackpot! The tires, front and rear are good! They are almost new. The previous owner had bought a old wing as a donor bike and included a box of parts. In this box is two complete sets of ignition systems! the stock set and a Dyna Set! Also in the box are two sets of covers, another gauge cluster and almost everything electrical except the harness. Heck, that may be there too since I still have not found the bottom of the box!
SO, I may not have to pull much from this "donor bike" after all and I may have just found my next project! We shall see how this goes!
Re: 78 Blue Baron
Kewl Beans, nice donner.
