79 GW EFI Project
kb0ou
Re: 79 GW EFI Project
#121
Post by kb0ou »
UPDATE !!!!!!!!!
Got power to the computer system!!!!!!!!!! action1
Still have a few wires to hook up................
You might notice a red wire just kinda hanging in the picts, it is the 12 volt line to the MicroSquirt, I plan to not hook that up until I am ready to plug it in to my laptop. I think that will be tomorrow.
I have hooked up so far:
Oxygene sensor,, actually seeing a signal on the volt/ohm meter
Ignition input, for rpm, from the existing ignition system.
That's it folks, there ain't no more!!!!
1979 Goldwing gave it away... :(
joedrum
#122
Post by joedrum »
im always lurking on your mod project ...i dont post much on it as im rather clueless on FI project but it looks like your getting to homestretch .....great going ...your quite the doer
1979 1000
KYpondman
#123
Post by KYpondman »
Looking good! I had a meter like that when I first started in electronics some 40 yrs ago.
Claude
mcgovern61
#124
Post by mcgovern61 »
joedrum wrote:im always lurking on your mod project ...i dont post much on it as im rather clueless on FI project but it looks like your getting to homestretch .....great going ...your quite the doer
No peeking Joe!
Gerry
Current ride: 82' GL1100
1st ride: 81' Suzuki GN400
kb0ou
#125
Post by kb0ou »
Yea that is my old simpson 260 I used to use them in the Navy a lot, when I got the chance I had to get one of my own.
I have others, like a nice Fluke, I just like the ole simpson.
It is like a bad habit.... ;)
Kriss
#126
Post by Kriss »
Hi. try looking at the new or old japanese cars or bikes for the temp sensor.
5x GL1000S, 2x GL1500,
kb0ou
#127
Post by kb0ou »
Kriss,
What temp. sensor are you talking about???
I think I have all I need right now.... :orange
kb0ou
#128
Post by kb0ou »
Update,,,,,,
I feel like a real electrician now :orange
Wednesday 12/28/11 I got all the wires I will be using now from the MicroSquirt wired to terminals so I can hook up sensors and check voltages with the volt/ohm meter.
No pictures, I will try to take some this week.
Happy 2012, just think, a year or so ago this was just an IDEA, What was I thinkin????????? confused22
#129
I'm anxious to see how this goes too.
badorderbob
#130
Post by badorderbob »
Update Please type1 !! :crosso Bob
Robert White
#131
Bump,
kb0ou
#132
Post by kb0ou »
Ok, OK!!! ;)
I have been working on a Tilt switch and working on my Ham Radio station some.
I purchased several tilt switches to check them out and see if they would work. More later.... :guitar
I have been working on Grounding my 40 foot tower for my Ham Station because I am going to install a sloper antenna for 80 and 160 metres. A sloper antenna uses the tower as part of the antenna and it needs a very good Ground to work right, so I drove 3 ground rods in the ground and attached them to each of the 3 legs of my tower. I will do some radial wires later.
Besides that it has been cold in the shop lately, my concrete floor gets really cold and stays that way. So, that has kept me from doing a lot out there.
Thanks for the interest and the bump, more later.......... John kb0ou............ :crosso
#133
Patience, Grasshopper ....
. I've been told that before. Sorry, I guess I'm a cricket.
badorderbob
#134
SO how's it goin!! type1
Robert White
Toehead
#135
Post by Toehead »
kb,
The project looks great!
Please let me know if you have any questions. I might be able to help, as I have a lot of experience with megasquirt and did a similar project on my camaro.
The only issue that immediately comes to mind from my MS days is smoothing of the Vac signal. With smaller motors you may need to restrict the line to get a usable output from the MAP sensor.
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
