2019 Spring Project: 'Layla'
Re: 2019 Spring Project: 'Layla'
#121
Rednaxs60 wrote:Very nice work. Enjoy reading about these projects and how the end product turns out, especially when everything is taken off the bike. Haven't got the courage up to take one of my bikes down to the frame. Learn something new whenever I read about these restorations. Keep up the good work. Cheers
Ha! Don't know if it's courage or stupidity, lol! It always starts out innocently enough.
"I'll just take the seat off and clean up a little more." Then it's the faux tank. Pretty soon you've got a pile of parts scattered here and there and you're wondering how you're ever going to get it back together.
#122
They’re easy to take apart ....
Gord anim-cheers1
'13 Honda NC700sa … TNG
#123
I spent the day (on and off) experimenting with the assorted household chemicals in an attempt to remove the green film from the gas tank. Acetone? Nope. Mineral spirits, nada. Lacquer thinner, CLR, tire shine, no chance. Way in the back of the cabinet, Zep commercial oven cleaner, probably a 20 year old bottle. Why not?
And it worked! action1 action1 action1
Onward and upward!
ritalz
#124
Post by ritalz »
Good to know. The 81 I'm starting on will need some cleaning.
pidjones
#125
Post by pidjones »
You said you tried carb cleaner. Most of those are primarily acetone.
Rednaxs60
#126
Post by Rednaxs60 »
Painted my 1500, now to put it back together. Have all the bits and pieces in Ziploc bags, but did miss a few. Heck of a jigsaw puzzle. Next on the list of major projects is to freshen up my '85 LTD paint. Searching for the decals.
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2008 GL1800 (sold)
#127
The (hopefully) last major hurdle has been overcome! Fuel tank, battery box, and a few small bits prepped, primed, and painted. I still have a small box of assorted brackets, fasteners, and miscellaneous doodads to clean up and sort.
Tomorrow reassembly begins, starting with timing belts, setting the valves, replacing the coolant tube o-rings, and replacing the tach and shifter shaft seal. If all goes well, I should be pretty close to having all the engine mechanicals and wiring completed by the end of the weekend.
Liam
#128
Post by Liam »
Nice paint job. Looks like new.
Jonesz
#129
Post by Jonesz »
Great job on that tank Track T.
Jonesz
1979 Suzuki GS850. Sold
pidjones
#130
Post by pidjones »
Looking so nice. Too bad it has to be jambed back in. Protect it well!
#131
Spent most of the day 'communing' with Layla...
Shiny! I must admit I'm waxing the frame. Can't say that I've ever waxed a frame before, but I'm hoping it will cut down on road grime buildup, etc. Also finished cleaning the 40 years of accumulated grunge from the writing harness and around the gauge cluster and steering head. I did notice a few spots around the swingarm that I missed, so I'll have to revisit that.
The timing belts, new coolant crossover tube o-rings, and a spiffed up radiator shroud got installed as well. Tomorrow I'll set the valves, lube cables, install the carbs, fuel pump, coils, and get started on the electrical components.
Rednaxs60
#132
Post by Rednaxs60 »
Very nice. Won't be seeing a clean like this for another 40 years.
Ernest
2008 GL1800 (sold)
Liam
#133
Post by Liam »
Wow, that paint looks magnificent.
#134
Liam wrote:Wow, that paint looks magnificent.
That's the original frame paint, and except for some stone chips on the lower front crossmember and the front lower engine mounting tabs, it's in very good condition. Oh, and the front down tubes where the fairing and engine guards mount. :-? The swing arm is kind of battered with stone chips, too. I'm guessing the bike saw a bit of regular use on gravel roads at some point. Even the transmission cover looks beat up compared to the rest of the engines paint.
#135
Waxing the frame ?? :shock:
Sorry .... this makes it impossible for me to continue our relationship ....
Gord anim-cheers1
