1986 Aspencade Resurrection
3KidsinAustin
Re: 1986 Aspencade Resurrection
#121
Post by 3KidsinAustin »
CYBORG wrote: Mon Jun 09, 2025 7:04 pm Sometimes just need brushes as well. And they are cheap
You are right. Minimum spec is around 5.5mm - the brushes in my starter were around 10mm, so I just cleaned them all up.
1986 Aspencade (Complete!): https://ngwclub.com/forum/viewtopic.php ... 77#p829477
1986 SE-i (Current Project): https://ngwclub.com/forum/viewtopic.php ... 25#p831425
1984 Interstate (Future Project)
#122
:2thumbs :2thumbs
3KidsinAustin
Tire Tackling, Round 2
#123
Unseasonably cool, overcast weather this morning, so a great time to get out and clean up the rear rim. Went after it with some medium grade steel wool and worked it pretty hard. Picture shows the difference between before and after.
To remount the tires, I used a set of 48" zip ties. Doing this eases installation greatly as you only after to work the tire over the rim once - I'm a big fan. By the time I got to this point, the sun had popped back out, so I left the tire in the sun for a couple of hours, zip tied it, then rubbed the bead and the rim with soapy water.
I tried to get fancy with some QuickJack blocks to keep the wheel elevated, but it kept falling off when I tried to work the tire over the edge of the rim. After laying it directly on the cardboard I was able to work the tire over in sections, not too bad.
Next, the part I'd been dreading. Filled it up with air and checked for leaks after bouncing the inflated tire around. One side was perfect, the next had the slightest of leaks in two areas. Crushed, I went inside and pondered the meaning of life for awhile. After a spell, I proceeded outside, took my rubber mallet and proceeded to whack the bejeezus out of the areas where it was foaming. First, I hit the tire around the rim (not actually hitting the aluminum, just the rubber), then after a few sessions I really went after the larger tread area. After three or four beatings, the wheel must have decided resistance was futile and the leaks have stopped. For now... I've celebrated before, so I'm holding off for awhile before claiming victory. Regardless, here is the tire as it now sits, temporarily bested by an angry guy with a BFG.
#124
Just wow, now I know why I go to a tire shop.
3KidsinAustin
#125
Fred Camper wrote: Tue Jun 10, 2025 6:31 pm Just wow, now I know why I go to a tire shop.
I agree! None near me or that would be my first stop. I think my next trip to Autozone, I'll pick up some tire bead sealer as I need to replace both tires on the upcoming 84 project. I had zero trouble on the front tire that I replaced on the 85 but this one beat the band.
3KidsinAustin
Head Coming Off Again
#126
The good news is that I have found incontrovertible evidence of the cause of my oil leak. The bad news is the left head needs to come off, again. This is the one I removed earlier to play with the valves. There is a section of head gasket completely missing down in the oil return area. I was watching it on my back while the bike was running and with a flashlight pointed in the area. I could shine light through the opening and confirmed it by sticking a feeler gauge through the joint.
Looks like a project for tomorrow. Drain coolant, drop radiator, remove exhaust, intake runners, alternator and pulley, set timing, remove belt and cam pulley and THEN the head can be pulled. I'll be interested to see the gasket - will certainly be plenty careful putting the second one on!
3KidsinAustin
An Exercise in Humilty...
#127
I wish to humbly thank this motorcycle for giving me so many opportunities to succeed, despite my best efforts. Today was spent going through the process of removing the cylinder head to change the gasket and reinstall. As I mentioned yesterday, there was an area in the head where there was no gasket sealing it to the block. Avid readers might recall I attributed this to a damaged head gasket.
Your Honor, I submit the picture below as evidence against the moron currently sitting in front of the keyboard...
Yep, I installed the gasket backwards. For readers that have not had the privilege of digging into the upper half of the engine, the proper orientation of the gasket is as follows:
I managed to leave a sizeable portion of the drain cavity exposed. Oops.
All is reinstalled and working properly. Still a bit of oil on the exhaust headers that is burning off but no leaks identified yet.
Waiting on an oil seal for the leaking rear shock absorber then the bike can be reassembled and road tested again. So far no air leaks on the rear tire.
#128
Good news on the rear tire, that was one big learning event.
3KidsinAustin
Accidental Low-Rider
#129
Fred Camper wrote: Thu Jun 12, 2025 10:43 pm Good news on the rear tire, that was one big learning event.
Been a couple of days and still holding air, so I mounted it back under the bike. Had to deflate it to 20psi then reinflated, so I think I'll do another soap test just to be 100% certain.
With the rear suspension off, the old gal really takes on the "slammed" look.
3KidsinAustin
Rear Shocks Installed
#130
Took longer than I expected and looked like a slasher-movie aftermath with ATF everywhere, but I got the oil seal replaced in the leaking rear shock. Everything is starting to go back onto the bike but the heat was getting to be too much after the couple of hours I was out there putting the suspension back together. Hopefully get some test rides on it soon!
#131
Good news but sorry about the heat. Mornings are your friend for a while.
3KidsinAustin
#132
Fred Camper wrote: Tue Jun 17, 2025 9:29 am Mornings are your friend for a while.
My friend, you speak the truth! Took it for a test ride earlier and had ups and downs. The oil seal on the rear shock is doing its job, so that's a plus. Downside is the speedo fix I posted a few up was again non-functional. Fortunately, I had one last chip to solder back in. This time I left out the silicone and running it dry. If it holds up, I'll probably look at some proper potting material. Also had a leak from the upper radiator hose (I hope that is where it's from). Had to pull out the alternator to get a good grip on the band clamp and really gave it the business with some serious tightening. Felt like a little moisture coming off the right side as well, might be from the overflow tube. I'm riding with the tank shelter off just so I can try and spot these little things.
Daughter itching for a ride on the back, so I through the bags back on to keep her in a more confined space. Will surprise her with a ride after her swim team lessons in the morning.
#133
3KidsinAustin wrote: Tue Jun 17, 2025 7:58 pm
snip
If the radiator hose and hose connection surfaces are clean and intact, these "hose clamps" are quite likely the solution
viewtopic.php?p=814021#p814021
I don't know whether those pictured "hose clamps" are the same size the 1986 Aspencade would require, though.
Scroll down this size selector chart
https://www.gates.com/us/en/fluid-power ... 00000.html
Cliff ;) )
3KidsinAustin
No Leaks, Fuss or Muss
#134
Thanks for the tip on the hose clamps! I went to the website, very innovative idea. Fortunately, I just needed to remove the alternator to get better access to the clamp and really tighten it down, as I evidently just used wimpy muscles the first time.
Took the old gal out for a test ride through the neighborhood this morning, then with it warmed up I re-synch'd the carbs. Very nice throttle response and ample power when cruising. Had my daughter on the back for the followup ride and she is giving it a hearty thumbs up!
I've been using my CarbTune a bunch since getting back into bikes. It was state of the art when I bought it 15 years ago! I've seen digital variants and thinking about building one of those as an off-season project.
For now, will be bolting the remaining pieces back on the bike, cleaning it up, and doing a few more shakedown runs before getting it sold.
Here is a short clip of the bike with the CarbTune hooked up.
https://youtube.com/shorts/nCqj6RK8Y-M[/youtube]
#135
WOW! 😀
That's a Very Well Behaving engine tumb2
Cliff ;) )
