My Wing
- theailer
Re: My Wing
WOT cold
Front right, 205
Rear right, 210
Front left, 190
rear left, did not test this when cold. I had the charger on but seems the battery started to sag too much.
						Front right, 205
Rear right, 210
Front left, 190
- theailer
Re: My Wing
Warmed up engine for 15-20minutes, started with the rear left cylinder:
Front right, 200PSI
Rear right, 200PSI
Front left,190PSI
Rear left, 180PSI
Seems to be alright, and the leak down test also confirmed the cylinder/pistons/valves to be in order.
						Front right, 200PSI
Rear right, 200PSI
Front left,190PSI
Rear left, 180PSI
Re: My Wing
Near 20% leak down isn't great though. That high you should have some air leaking someplace.
Re: My Wing
While your numbers are good, your #4 cylinder (rear left) is out of spec of between the others.  You can try putting a few drops of oil down in that cylinder and try your test again to see if it comes up.  May want to revisit the valve adjustment on #4 as well.
- theailer
Re: My Wing
Cold motor
#4 Rear left, 160PSI
With a touch more than a teaspoon of oil: 175PSi
Re: My Wing
Chances are you have either a collapsed ring, or worn rings…either way that cylinder is low.
Re: My Wing
Maybe I missed it. What does the plug in that cylinder look like compared to the other 3?
Re: My Wing
I would not loose sleep over those numbers
- theailer
Re: My Wing
Thanks
Weird thing is that it smokes out of the right cylinders. Maybe all of the rings have aligned to the exact same position letting oil through?
Re: My Wing
don't those individual cylinder compression test result numbers seem unusually high?
Are the GL1100 engine compression test numbers specs that much higher than the Honda Shop Manual GL1000 test specification of 171psi?
Re: My Wing
no
- theailer
Re: My Wing
Guess it could be the tool that is not of the highest quality?gltriker wrote: ↑Wed Jun 19, 2024 12:21 pmrobin1731
Re: My Wing
I never put much faith/stock in compression numbers. I look for consistency. And I use the same gauge for any engine so at least that part is the same. There are things that can change the numbers too even on the same engine with the same gauge. Compression gauge is a good tool no doubt. But you need to follow that with a leak down. And you need to listen for where air is escaping from. There will always be some. You just don't want a lot.gltriker wrote: ↑Wed Jun 19, 2024 12:21 pmrobin1731
- theailer
Re: My Wing
Ran the bike for roughly an hour and then stopped and let it cool before I removed the spark plugs:
From left to right,
#2,#4 #3,#1
						From left to right,
#2,#4 #3,#1
						- theailer
Re: My Wing
Santa came early this year
Managed to find a brand new speedometer for another Honda on ebay for reasonably money. It is not geared the same as the GL so I might need the drive of a CB550/750 or similar if it fits the axle. Or just relearn what the different speeds are
