Stator plug replacment done right
- scmedic6
ststor wiring
Just found out that I had this problem. when I tried to get the wires out, they all came out at one time. Is there any certain order that they go back together?
1978 GL1000 naked restoring
1983 Gl1100 dressed just aquired
- mooseheadm5
- pugetsoundsailer
where do you get replacement plugs?
Ride'on.............
78 Naked Custom GL-1000
84 GL-1200 Standard
88 VN-1500
98 XR-400
84 GL-1200 Standard
88 VN-1500
98 XR-400
- technojock
- pugetsoundsailer
Thanks Tony......................
Thanks.............
84 GL-1200 Standard
88 VN-1500
98 XR-400
84 GL-1200 Standard
88 VN-1500
98 XR-400
- kitbutterfield
- pugetsoundsailer
Great plug, good quality connectors too plus he sent me a couple spares........technojock wrote:You can get the plugs here.
http://www.oregonmotorcycleparts.com/connectors.html
Tony
Just like new now....................
84 GL-1200 Standard
88 VN-1500
98 XR-400
84 GL-1200 Standard
88 VN-1500
98 XR-400
- technojock
- 78AZWing
I just soldered my alternator to regulator connections.
Shoulda done it when I first read about it. In thinking back on it, I am willing to bet that plug is the cause of my poor idle, and not the carbs. Weak spark and the lights stealing current from the ignition and the curcuit wouldn't handle the current needed for the lights and ignition to run right.
I added six inch sections to each wire, to be able to get enough for them to connect together. Mine were short after cutting the plug out. I just clipped the wires dead even with the plug surfaces.
Heck it shows a charge (barely) at idle now!
I am still considering LED tail and turnsignal lights, though.
For that run-down feeling -
Try Jaywalking!
1978 'Wing with Weber conversion, UnDressed
1976 Junkyard 'Wing with a Dyna ignition. Otherwise undressed.
Proud member of the "NGW CARTEL"
Try Jaywalking!
- technojock
- roncar
- technojock
