Carburetor Removal, GL1100
roncar
Post by roncar »
Roady wrote:.......Some very nice things have come out of this. My lovely bride now knows that I will not be selling this bike. She is happy for me. And soon, there will be an order going out.........
.......Waiting on the ca$h to order Randakk's 1100 Combo.
Is she about $200 happy? dancr dancr dancr
In the next couple of weeks she will be.
Yahooo!
I just now ordered Randakk's GL1100 Kit with Howard's book. There is no video for the GL1100.
Had a yard sale this weekend and came up with enough to cut loose and finally get the kits. And there's a bunch more room in the shop and basement as an added bonus.
I'll start a new thread for the rebuild, I gotta take pics, ya know?!
Frenchy
Post by Frenchy »
He may not have a video, but he offers an awesome step by step how to book for the gl1100 carbs!!
Frenchy
78AZWing
#20
Post by 78AZWing »
Does he or anyone else do a kit for the 1000?
(memo to self - must do a search on this topic.)
For that run-down feeling -
Try Jaywalking!
1978 'Wing with Weber conversion, UnDressed
1976 Junkyard 'Wing with a Dyna ignition. Otherwise undressed.
Proud member of the "NGW CARTEL"
78AZWing wrote:Does he or anyone else do a kit for the 1000?
Yes he sells what you need. Plan on spendng some time here http://www.randakks.com/
78AZWing
#22
Post by 78AZWing »
Can the 1000 carb pack be removed the same way that Roady details for the 1100?
Mine is only running on the 1/3 carbs at the moment and with the points and coils firing front cylinders then rear cylinders the problem is most likely the passages in the 2/4 carbs are gummed up.
And have been reading all Randakks' articles on the 1000. Great stuff!
Thanks for the answers.
Try Jaywalking!
Yes it is basically the same but I don't remove the seat or the intake runners. I will try to do a verbal How too on this tonght so as not to clobber up this thread.
78AZWing
#24
Post by 78AZWing »
I need to totter off to bed, Working nights is a drag.
If the removal is basically the same I should be able to follow Roadys directions and take the whole rack off if I need to. Think I will try Randakks' quick methods first and see if that will kinda clear up the problem. Plus a new set of points as I am not sure how old they are at all.
I just went out and checked all the mixture screws and found them all close to 6 or 7 turns out. Ran them all back into 2 turns out. Surprised it ran at all. :shock:
Thanks again.
Try Jaywalking!
curtis.71
Vacuum Tube
#25
Post by curtis.71 »
In the tenth pic it shows the vacuum tube,I havent had this bike long but noticed where the vacuum tube is suppsed to be mine is missing where does the other end goto
help
Sagebrush
#26
Post by Sagebrush »
curtis.71 wrote:In the tenth pic it shows the vacuum tube,I havent had this bike long but noticed where the vacuum tube is suppsed to be mine is missing where does the other end goto
It goes to the vacuum advance mechanism located at the top right rear of the engine. In the picture below its the circular part at the extreme left with the little pipe going towards the front. The pipe part is wrapped in tape to prevent it from being painted in the picture. The vacuum hose fits on the pipe.
curtis.71
thanks
#27
Post by curtis.71 »
I see where you are talking about, Maybe ill get a chance tomorow to lacate it and fix,if this has been off what kind of problems would this cause
help
firehawk
Lead Member
Lead Member
Re: Carburetor Removal, GL1100
#28
Post by firehawk »
if your not the mechanic type and scared that your going to do more harm than good attempting to clean your carbs/me. Is there anythng I can try to run thru with the fuel that will help or anything \i can spray into the carbs that might clean my fuel starvation problem. It runs when I get out into second gear. I have to keep the idle up to 20000 when i come to a stop or it will die?
1979 GL1000
firehawk
Lead Member
Lead Member
#29
Post by firehawk »
Has anyone had a problem with fuel dripping from below your engine just about where the til pipes leave the block. I started my bike and \i can see a pretty heavy flow that appears to be black in colour but smells like fuel not thick like oil.
1979 GL1000
#30
Most of the guys down here in the South run a bit of Marvel Mystery Oil in every tank. Seafoam has also been touted as an excellent cleaner to use occasionally.
I generally run 89 Octane straight up. The more the better.
You may be looking at a carb job.
