Another 1100 raised from the dead
nice photos!
I want one of those 78 trashed frames w/ a title! Got a line on a 78 engine that I'd like to toss in a project down the line.
- Sagebrush
The VIN is stamped into the steering neck on the opposite side from the manufacturer's plate. Anyone in the know would look there and not be fooled by swapping the plate.Roady wrote:Very nice attention to detail there.
Might save someone some trouble on a non-titled bike. Buy a crappy but titled frame and presto change-oh.
Well, obviously I did not know that. Dayum.Sagebrush wrote:The VIN is stamped into the steering neck on the opposite side from the manufacturer's plate. Anyone in the know would look there and not be fooled by swapping the plate.
But I guess a frame swap is not so bad ... the process gives the opportunity to inspect, clean, paint and renew everything.
- Sagebrush
More progress. We are sprucing up the engine that I talked about in this thread >Click Here< and going to put it in this bike. I fixed the missing pin problem with a dremel, 4mm screw and some JB weld.
Removed the transmission cover, clutch cover and timing belt covers. Put in new clutch plates. Stripped and cleaned the engine along with all the covers. Primed and painted.
Grandson masking off the engine after stripping the paint and cleaning:
Primer Coat:
Color Coats:
Clear Coat:
We'll begin reassembling the engine tomorrow. More to come.........
Primer Coat:
Color Coats:
Clear Coat:
- Sagebrush
engine complete
Engine primed, painted and cleared. Reassembled and ready to put in the frame. Actually the frame was put on the engine, much easier.
Repacking those swing arm bearings...
Swing arm installation:
By the end of the day engine in the frame, swing arm installed, brake pedal installed and the radiator installed. It's Miller time!
Good Stuff!! Love to see a youngun involved.
Nice clean work, really nice. That gasket for the fuel pump looks really nice.
- Sagebrush
Thanks, and it should look good, its newsunnbobb wrote:Nice clean work, really nice. That gasket for the fuel pump looks really nice.
- Mike-C
- confish86
- My Album: http://www.ngwclub.com/gallery/v/wingmans/album169/
- Sagebrush
For inspiration we've taken Hardware Man's beautiful half bagger. This is the look we're going for, including the flames. We're going to paint it the same color as my wife's trike, Apollo Pearl Blue:confish86 wrote: I`m woundering , are you going to full dress her , or make a back 1/2 bagger & what color you thinking of painting her.
- confish86
Wow
Nice trike you got there (hope you get to ride it sometimes) Blue would look great on the 81 - 1100. As for Hardware mans bike (swing
) That should be an insperation too all 1100 owners.
IBA # 47424 (yahoo)
76 GL1000 (Naked)
78 GL1000 (dead title , but got a 79 frame for it)
2012 Kawasaki Concours (LD bike)
Ban low performance bikes....NOT high performance riders!
76 GL1000 (Naked)
