Shortening Shocks
bum
Post by bum »
yes, it sure helped me...................28" inseam 8)
bum
8 wings + 1 Triumph +2 Musclecars = 1 pissed off wife !!!
It will help ... but you might want to try seat mods, different seat before going to the trouble.
A narrower front of the seat has helped many and it's an easy modification to make. Just takes time, hacksaw blades, patience and a staple gun.
Victour
My Album: http://good-times.webshots.com/album/570131144RgmY
Post by Victour »
Ok I am a 28 incher myself my 750 caused me to be tippy toes Scary. a English dude also short turned me on to Laybacks. Mine were chrome and bolted to the lower shock mount then extended back about 1 1/2 inches with the shock mount hole..This slanted the shocks back thus lowering the bike where I could stand flat footed.. How great.. I am going to make some different for my wing.. but the same concept.. there shall be pics...
1978 Gl1000 LTD
http://good-times.webshots.com/album/570131144RgmYiK
FirstYearDeek
Post by FirstYearDeek »
Victour wrote:Ok I am a 28 incher myself my 750 caused me to be tippy toes Scary...
Eek! 750's are top heavy. Scary indeed.
That bike taught me to respect bigger machines.
-Deek
therealmark
#20
Post by therealmark »
Yeah that rocks! Wish I knew this before I went through all the issues with the redwing shorties... I still have the 'wing shocks so I might just do it anyways sometime.
'78 GL1000 and '76 Volvo station wagon with 350 chevy.
geddisleroy
Brass Member
Brass Member
shorting shocks
#21
Post by geddisleroy »
How would you go about lowering the front 1" or so?
leroy
78 gl1000
1930 ford
1946 ercoupe airplane
KR2 home built airplane
sandrail dune buggy
Loosen the pinch bolts on the upper and lower tripple trees (2 allen head and two 14mm IIRC, 4 bolts total) and slide the tubes up in the trees. Best done on the centerstand with a small jack under the engine or a friend there to help. Sometimes a small wedge is needed to seperate the tree pinch points a bit.
Then go to a parking lot and pratice. A 1 inch drop makes a very significant difference in handling and it takes some getting used to so please be careful.
geddisleroy
Brass Member
Brass Member
lowering
#23
thinks for the input
leroy
78 gl1000
1930 ford
sandrail dune buggy
tk1971
Short shocks
#24
Post by tk1971 »
Anyone had issues with their side stand after shortening their shocks?
I bought a set of 11" CB750 shocks and find that my side stand puts my bike near vertical.
Cut and weld? If I go that route, will arc welding be good enough, or do I have to find someone with a gas setup?
Thanks.
Tony
FAIR is the only four letter "F" word I know.
Rides a 78 GL1000
RIP: 1950-2011
#25
Post by Cookie »
I'd cut and weld it myself. If you are OK with arc that should be fine.
tk1971
cutting side stand
#26
Post by tk1971 »
Yep. I cut my side stand about 1" and welded it back up with my cheap arc welder. I was concerned because the stand is solid and I was afraid that getting only a bead around the cut would not be enough to hold the weight of the bike. The good news is that after I welded it up (and let it cool down), I threw it around my concrete driveway and nothing came apart. The welds certainly aren't pretty, but I need to go to bed now. So, I put the stand back on the bike and it works like a champ. I'll grind it down later and paint it to make it look pretty again. This is a great How To. Many thanks to this site.
Tony
Rides a 78 GL1000
When ever you are welding a rod like a side stand take your side grinder and grind both ends to a rounded point. When placed together you should see a "V" shape that will provide much more surface area for your welds to work.
tk1971
welding
#28
Post by tk1971 »
Check...
Thanks.
tk
Rides a 78 GL1000
78AZWing
#29
Post by 78AZWing »
The JunkYard Wing has been lowered using laybacks and shorter shocks plus about an inch and a quarter of the forks above the triple-tree clamps. Sits almost straight up and down. Real easy to knock over to the right.
I was thinking about heating the sidestand in the middle and curving it outward an inch or so to return the lean angle to a more acceptable angle. Any thoughts?
For that run-down feeling -
Try Jaywalking!
1978 'Wing with Weber conversion, UnDressed
1976 Junkyard 'Wing with a Dyna ignition. Otherwise undressed.
Proud member of the "NGW CARTEL"
gungadin
#30
Post by gungadin »
peteybug wrote:Won't leave much room for travel. Mine are working great with just a little over an inch shorter.
Have you thoroughly road tested these Peteybug?
Do they seem stiffer having been pre-loaded by 1" ?
I noticed that the shorter shocks don't have the 2 stage springs? Or have you tried it with them too?
This is cool. I'm going to do it.
'75GL "LIL WING"
If you aren't making mistakes you aren't doing anything.
