remove rear break sticking
Re: remove rear break sticking
freedom wrote:The pictures by Peteybug show an error message right? My rear brake pedal is stuck and I found this thread but without pictures it is not much help. Hopefully he can post the pictures again. Thanks in advance.
I don't think Peteybug is active any more. In any case, are you concerned about getting the pedal off, or adding a grease zirk? If the pedal is froze, penetrating oil, such as PB Blaster or the like, followed by some persuasion is your best bet. Eventually, it will come loose. Good luck!
freedom
Zinc Member
Zinc Member
Post by freedom »
Thinking of adding a grease zirk. Thanks
