White wall tires for the GL1000
- Lead Member
Thanks Gunny. That information is very helpful. I wonder if you can tell me anything more about the rear wheel you mounted the 16" tire to. I have ordered a 16" Lester wheel that was made for the GL1000, & I wonder if thats what you have? Can I expect to have to "shave" down the driveshaft also? If you don't have a Lester wheel, what do you have etc.?
- Lead Member
Gunny's GL1000
They are Lester Wheels. They made wheels for many different bikes back in the 1970's and 80's they are out of business now as most new bikes started coming with mag wheels from the factory. They sell now for around 400.00 a set if you can find a good set. The ones on this bike were new old stock when installed in 2001. The assembly of the drive shaft housing did not look to be a precise piece. There was a seam on mine that was a little overkill so we took a portable grinder and shaved it down without breaching the housing so as not to let moisture in there. Jundging from the amount that had to be trimmed I would say it would be a safe bet that you'll have to do the same. "Cycles Unlimited" in Decatur Alabama put the tires on and did the shaving as a courtesy. Not a big deal. I really like the 16' wheel in the rear and the front forks were dropped down 2 inches to give it a lower stance and with the tank being under the seat it has a low center of gravity combined with these tires make it a fun ride!
Gunny
Gunny
- Try
- NGW Founder
- My Album: http://www.ngwclub.com/gallery3/index.p ... wing-album
Re: Gunny's GL1000
Hello and welcome aboard Gunny.Gunny wrote:I really like the 16' wheel in the rear and the front forks were dropped down 2 inches to give it a lower stance and with the tank being under the seat it has a low center of gravity combined with these tires make it a fun ride!
Very nice of you to join us and answer question.
Thank you very much.
Try
"84 - GL1200 Standard
Try
- Boxern
Re: Gunny's GL1000
wlcome to the group gunny very nice gl1000Gunny wrote:They are Lester Wheels. They made wheels for many different bikes back in the 1970's and 80's they are out of business now as most new bikes started coming with mag wheels from the factory. They sell now for around 400.00 a set if you can find a good set. The ones on this bike were new old stock when installed in 2001. The assembly of the drive shaft housing did not look to be a precise piece. There was a seam on mine that was a little overkill so we took a portable grinder and shaved it down without breaching the housing so as not to let moisture in there. Jundging from the amount that had to be trimmed I would say it would be a safe bet that you'll have to do the same. "Cycles Unlimited" in Decatur Alabama put the tires on and did the shaving as a courtesy. Not a big deal. I really like the 16' wheel in the rear and the front forks were dropped down 2 inches to give it a lower stance and with the tank being under the seat it has a low center of gravity combined with these tires make it a fun ride!
Gunny
[img]http://www.nakedgoldwings.com/forum/images/flags/Norway.gif[/img]
1978 gl1000
1978 gl1000
- Lead Member
Thanks so much for the info Gunny. I've ordered a Lester 16" rear wheel & Also the same Maxxis tires you've got. I'm on the lookout for a Lester 19" for the front, but if I don't find one I'll have to use mismatched rims. I have saddle bags on my bike so it won't be quite as obvious. At any rate I'm expecting those tires to dress it up a lot & I'm glad for the direction.
- Lead Member
white walls
No problem John. I apologize for the tardy reply but I had no idea how extensive this site was until a few days ago. I would have replied sooner but am still learning how to navigate through. I get on e-bay any chance I can and will keep an eye out for that front rim. it's the least I can do for a retired firefighter. FYI, the first set of Maxxis tires that Dennis Kirk sent me had to be returned. I did not feel the white walls were as white as they should be (blue stain) I called Maxxis and they said that they have had that problem before but it was not wide spread, a few here and there. I returned the set for new and was very pleased. As I understand it, if the blue protective strip is placed on the tire before it completely cools then that is what happens. Let me know how it goes.
Joe "Gunny"
Joe "Gunny"
- Try
- NGW Founder
Re: white walls
I have been wondering about that, thank you for the explanation Gunny.Gunny wrote: As I understand it, if the blue protective strip is placed on the tire before it completely cools then that is what happens. Let me know how it goes.
Try
Try
- Lead Member
- Zryder
- My Album: http://www.ngwclub.com/gallery/v/wingmans/zryder/
- Lead Member
another option is to find a 75 or 76 rear spoked wheel. Then respoke to the 16'' rim. There is a place in California that does a very good job of making the spokes. Their name is Buchanan Spoke and Rim Inc.
http://buchananspokes.com/
2fer-bob
78 chopped
82 I
in Wisconsin
78 chopped
82 I
in Wisconsin
- Lead Member
- BIG T
- My Album: http://www.ngwclub.com/gallery3/index.p ... ustom_wing
white walls
hey all check this site foe whitewall tires in all goldwing sizeshttp://www.jpcycles.com/productgroup.aspx
please donate to keep this site alive.
admit nothing, deny everything, demand proof!
- BIG T
white walls
try this swite for goldwing white wall tires in all the sizes
