viewtopic.php?t=79155#p830592
The NGW Project Bike. Wheel rebuild
Locked
Bandanna
Post by Bandanna »
YOU ARE THE MAN!!!!!!!!!
lost for words.......... :shock:
BRILLIANT SIR........... ;)
Zryder
Post by Zryder »
I Thank You kindly Octane . Just want I need for my reserch . So far its on the drawing bourd that I may trike my bike so I am looking into the internal workings of the swingarm in mounting the rear of the trike assembly . In Adam Es words and I also feel You are the Master tumb2 .
octane
Post by octane »
ho ho ...give me a break .-)
I'm just what around here is called "a happy amateur"
...not too smart
...but enjoys what he's doing
...and mostly gets away with it
Thanks guys!
Annie's Boyfriend
Post by Annie's Boyfriend »
Don't be so modest, we are all very happy with the info that you provide.
So far it has been a great help :-D :-D :-D :-D
Bart
Annie
Dreamboat Annie
Little Ship of Dreams ...........
( lyric from "Dreamboat Annie" by Heart)
[url]http://www.nakedgoldwings.com/gallery/Dreamboat-Annie[/url]
[img]http://www.hondagoldwings.com/images/cliparts/eagle3_small.gif[/img]
[img]http://www.nakedgoldwings.com/forum/images/flags/Netherlands.gif[/img]
rrgrassi
#20
Post by rrgrassi »
Hey Octane,
Also make sure to get your speedo recalibrated. Smaller diameter wheel turns faster than a larger diameter.
As I recall from my automotive experience, reducing wheel diameter did cause problems with ground clearance and ride height and angle of deflection when bumps and dips were encountered while driving.
RRGrassi
75 GL1000 With 80 CB900C suspension and Lester wheels.
Keep the rubber side down!
Needle
Zinc Member
Zinc Member
#21
Post by Needle »
Thanks Octane,
You answered a lot of my questions, before I asked them. I am trying to a similar thing with my front wheel off my 75 Wing. I bought an extra 17 rear rim that I want to lace to my front hub. That will give me 140's front and rear. Can I use a die and just thread the spokes farther down and cut them to the size I need? That way I could use the original front spokes. I also want to paint my spokes like you did, your wheels look awesome. Thanks for documenting all your hard work it is an invaluable asset to all of us!
Mahalo,
Needle
Aloha,
Needle
78 XS750SE
83 GL1100 (Donor Bike)
00 XL883
Put something exciting between your legs.....ride a motorcycle!
octane
#22
Post by octane »
rrgrassi wrote:Hey Octane,
Hi RR Grassi, thanks.
Oh yes I know I'm f.... er.. fooling with the speedo ratio and
with the whole geometric set up of the bike.
Yes you're also right about the 'deflection'-thing.
That's why off-roaders have such big (front) wheels.
Thy're much better at absorbing bumps.
We'll see how it works out.
Best regards
Octane
octane
#23
Post by octane »
Needle wrote:Thanks Octane,
Mahalo,
Needle
Hi Needle please see my post to Bart on the previous page.
I'm not a wheel build expert but I'd say, yes you can
use a die and just thread the spokes farther down and cut them to the size,
you might have a slight problem if they are
galvanized, or have some other surface treatment that you
cut into, threading them. Then again if you paint them
that should keep them from rusting.
Here's a few links if you want to dive into it:
Click
Click
Click part 1 , Click part 2
Octane
Da' Supercharged Bulldog
Antoine de Saint-Exupery
Annie's Boyfriend
#24
Ok, it is time for another dumb question.
How can I best remove my frontwheel, do I have to jack the bike up or do you have another tip for me.
Be aware that I do not have a motorlift or table to work with.
I was thinking of placing her on a big plank or something, leaving the frontwheel off of it so that I have some room to drop the axle/wheel out.
Ideas ??
Bart
Annie
Dreamboat Annie
octane
#25
Post by octane »
Annie's Boyfriend wrote:Ok, it is time for another dumb question.
Ideas ??
Yes: placing her on a big plank or something, leaving the frontwheel off of it so that you have some room to drop the axle/wheel out
sounds like a brilliant plan to me.
As I do have a lot of bikes to work on I've invested
around 60 UD$ in this super-nifty little sissor-type lift:
it's very usefull for detaching/reattaching the wheels
Raise/lower lift so wheel is on the ground...detach...raise etc.
Octane
RebelRouser
Webmaster (Retired)
Webmaster (Retired)
Post by RebelRouser »
Hey Bart, If Your Annie Is Fully Built And Weighs A Bit, Then Use The Center Stand As The First Point, Take A 2x4 And Go From Header To Header At The Front Of The Bike, Use A Standard Car Jack To Raise It, As The Weight Is Being Lifted Lossen The Nuts That Hold Th Axel Retainers And As You Lift The Bike The Wheel Will Stay Down As The Bike Goes Up.....
Hey Needle, Yes You Can Use Your Die To Shorten The Threads On The Spokes, As Long As It Is An Original Honda GoldWing Wheel, There All Stainless....
Hey Octane I Like The Red Pinstipe On Them Wheels, They Need It All The Way Around, Matches The Pinstripe And Racing Stripe Paint Job.....
77GL1
Zinc Member
Zinc Member
#27
Post by 77GL1 »
Not that "Mr" Octane needs any tips, but I was talking to a Rolls Royce guy that was telling me he tightened the spokes on his Phantom Is by tuning them like a piano....by sound. 'Course they're much larger than these.
[url]http://www.salocal.com/parts/goldwing_parts.htm[/url]
octane
#28
Post by octane »
77GL1 wrote:Not that "Mr" Octane needs any tips..
Hi 77GL1....oh yes he does
but I was talking to a Rolls Royce guy that was telling me he tightened the spokes on his Phantom Is by tuning them like a piano....by sound..
...right now "Mr" Octane got a tip on how he forgot to mention something in this thread.-)
Honda did give torque spec. for the spokes:
20-45 Kg-cm / 17-39 in. lbs.
As I don't have a torque wrench that would work on the spokes,
I simply put the square end of the torque wrench
(where you usually put on the socket) in a vice:
..adjusted it to first 20....(afterwards to 45 Kg-cm)
..held on to the torque wrench
at the same distance from the vice
as the spanner I used for the spokes is long
...turned until the 'click'
THAT gave me a good sense of what 20/45 Kg-cm felt like...force-in-hand-wise
Eh...did that explanation make any sense?
Also I checked all spokes by tapping them with a screwdriver,
(loosely held with two fingers)
checking for a clear PLING...not a DHUMPH.
And checking if any one spoke would have a distinctively different sound
from the others.
Witch, by the way, one should do every once in a while on ones bike.
77GL1
Zinc Member
Zinc Member
#29
Post by 77GL1 »
octane wrote:Also I checked all spokes by tapping them with a screwdriver, (loosely held with two fingers)
from the others.
Yup....the RR guy (w/60 years experience) said exactly that.........
Strawb
#30
Post by Strawb »
great stuff octane!!!!!!
did you have to replace the whole front end for this conversion?
'99 Honda CB400 Super Four Hyper VTEC
'81 Honda GL1100 Goldwing - WindJammer
http://www.nakedgoldwings.com/albums/album268
Locked
Return to “Octane's Corner”
