Leaf spring rear-end!!!
Sacrilege84
Re: Leaf spring rear-end!!!
Post by Sacrilege84 »
Mockin' up the new tank and relocation of the radiator. Gonna us the stock fan but i have to have a new custom radiator built. Styrofoam works pretty good if you dont mind it snowing in your garage. Also, finally figured out what i am gonna do with the coil packs as far as placement. But, i am gonna have to buy some more presentable coils.....any ideas? I am going to mount them on the triangle engine mounts.
here is a radiator setup....
Sacrilege84
Nice......but i really, really dont like to see wires. It takes alot of work and planning to pull off, but worth it to me in the end. Not only that but i am tryin to straddle the line between bobber/chopper and sport bike. Yea yea....i know...make up my mind right? So i try to keep everything low in the frame. Pretty cool though when yall find these examples....how do yall do it? Has anybody here on NGW done anything like mine?
I have not seen any yet bro. The radiator setup in the previous picture is just to show that rear mounted radiators are possible...
Hal
#20
Post by Hal »
ericheath wrote:Doesn't that have a spring on the inside? Along with the gas.
Absolutely not!
You can tell just by holding the OE coil sprung shock in one hand and the gas shock in the other...it's way lighter.
nor all your Piety nor Wit
1977 GL1000 in bits
1978 SR 500 Yam
2002 Caterham SV 220 Evo (4 wheeled motorcycle) :mrgreen:
Hal's Nalbum
gregforesi
#21
Post by gregforesi »
I think I can say with absolute confidence that you are treading virgin territory.
Have at it and have fun with it.
2006 GL1800 (Brutus Maximus)
Old Fogey
#22
Post by Old Fogey »
Please don't use the big ugly stock fan! there are much better options out there, like these
http://www.cbsonline.co.uk/category/Fans,b.html
Most autos use similar these days. Have a look through your local breaker's yard and see what you can find.
Sacrilege84
#23
Decided to do a bomb tank that will integrate the small drycell battery in the nose cone and hold the radiator on the tail. I have been looking for an actual Airforce practice bomb to modify but i can seem to find any that fit the bill. Any body got one layin around in the garage? If i cant find one in the next week or so i am gonna send this project to my buddies at the custom welding shop. Little to advanced for my small amount of welding experience.
The springs are at the spring shop having the bushings pressed in. It is a on the side job for them, so it may take a while! Once i get them back i will be able to make the shackles for the axle attachment. I am considering preloading the spring with a tight coil spring just behind the pivot point on the mounting bracket. This way i will get a little softer initial hit for the smaller bumps. Inside the coil spring i can put a rubber bump stop so that the leaf spring can take over from there?!? Just an idea. Tryin to make sure i keep my kidneys relatively in the same spot.
#24
Not sure you need to preload with more than a rubber bump stop, but no experience in this area.
Sacrilege84
#25
Fred.......I think you may be right! Maybe i can just put a big rubber stopper as the fulcrum stop and keep it simple!!! K.I.S.S right?
earthquake
#26
Post by earthquake »
I did a leaf spring seat on my bosses bike, [81 iron head sportster] it gives a very good ride.
all of the old seat mounts have been cut since the pic was taken.
Casey
"If it shines, bends, bangs or clangs, ITS METAL!!! and if I cant work it, I"ll piss on it!"
I love Boxer engines be GoldWing or VW
http://www.rememberingkelly.com/
WShie
#27
Post by WShie »
Hal, don't know anything about your shocks, sure are nice though. They appear to me to be upside down as the debris can fall onto the seal whereas if they were mounted the other way the debris would fall away from the seal. Just my opinion.
Bill
1979 GL1000- On the road again after 19 years
1980 GS1000G Current Moneypit.. er project
1976 KZ400- Winter Project
Gone but not forgotten:
1941 Matchless 350
1956 BSA Golden Flash
1956 Triumph 650
1977 Moto Guzzi 850T
1979 Yamaha XS1100
#28
Probably would not work so well, as the clevis is on the bottom.
Sacrilege84
#29
Finally got the springs back!!! Got to mock up the shackles now. Found a "energy suspension" kit at the auto parts store for 16 bucks that almost took care of all my bushing, taper washers and hardware issues in one swoop!!!!! Hope to have it all together by the end of the week (the leafs that is)!
Also started on the bomb tank. I gave up on the real thing. Never matched the size and the pocket book. Slice cut the tank and tapered it down to mimic the real deal!
SOOOOOo heres where i am at.......
#30
Crazy man.
