And away we go . . . . LTD style
- achmedachmed
- My Album: http://www.ngwclub.com/forum/viewtopic.php?f=30&t=34729
Re: And away we go . . . . LTD style
Ohh Man!! You are going way to fast
..You mean there wasnt even ONE screw that was stuck..keeping you busy for hours?? I had real fun the last 2 months
Very lucky so far. The bike clearly had been inside its entire life, and I put a drop of Kroil oil on about every screw and nut before attempting. We shall see if I get as lucky when removing the front cover. I have had trouble there before.
So you knew I was going to jump on the "timing belts look good" comment.
How'd ya guess?
You did have me going there.
How'd ya guess?
- Dog Boy
Ernie, sent you a pm.
AL
AL
They call me "Dog Boy"
Can't blame the "PO"
Original owner 76 LTD
Team 993
Team 993
STREETWING78
Some place in here someone had a paint match for the LTD's, gotta find it..
Have you opened the carbs yet? Fuel tank?
Tom
1976 LTD #276
1976 BLACK VETTER (soon to be naked)
1978 Naked(soon to be dressed)
1983 750 sabre(1476 miles) next project
1989 1500
1998 cr250
1974 bultaco 250
1973 suzuki tm125
1976 LTD #276
1989 1500
1998 cr250
1974 bultaco 250
1973 suzuki tm125
Tom, The gas tank needs work, but I think it will be ok. I will be getting out my Mr. Wizard contraption to de rust that bad boy. I have only cleaned up the outside of the carbs, but I think they will be fine too. What about your right hand starter switch. Does it have an on/off headlight switch?
STREETWING78
No on/off must an earlier honda part,72-3 maybe...
Tom
1976 LTD #276
1989 1500
1998 cr250
1974 bultaco 250
1973 suzuki tm125
1976 LTD #276
1989 1500
1998 cr250
1974 bultaco 250
1973 suzuki tm125
- Dog Boy
Ernie, I'm super impressed with your progress.
Money and time have been my 2 worst enemies and know I'm not the "Lone Ranger", when I make that statement.
Great job!
AL
Great job!
AL
Team 993
Team 993
Thanks Al. I love doing this! Tom, Why would any bike have an on/off headlight switch? Other than at start up, why would you want the headlight off? It looks more black in color than the other side which has kind of a purplish color. You wonder sometimes what has happened to these bikes over the last 35 years.
- roncar
That top half not being faded like the bottom half, makes me think it's been replaced. The replacement must not have fit properly, so only the top half was replaced.polkadot77 wrote:...It looks more black in color than the other side which has kind of a purplish color....
So far as the headlight switch, only models destined for North America (NA) did not have the headlight switch. The rest of the world (ROW) does. It may have been the only replacement control available was a rest of world style. Besides the headlight switch, internal wiring is also different, so only the top half was replaced. Some of the differences.
1. starter switch - NA also disconnects power to the headlight when pressed (ROW does not.)
2. headlight switch - NA not available (ROW in the OFF position also disconnects 1 leg of the stator.)
3. kill switch - same function on both
roncar, interesting! I did not even notice the difference until I tested the lights and the head light didn't work. I hit that switch and on it came. The high beam then was controlled by the left hand switch. I didn't notice anything different when I pulled the wiring harness apart. Kind of cool, but when would I want to turn it off, except at startup? I would be more afraid that I was riding and forgot to turn it on!
- Graham Cracker
Could the switch be from another brand and not Honda?
Mark
1976 GL 1000 Sulfur Yellow
1977 GL 1000 Pearl White
No, I'm sure its a Honda switch. It fits perfectly and looks just like my 77 switch except for the on/off switch. Roncar's explanation sounds reasonable to me. My frame and motor numbers match US numbers. Do we have any LTD owners on the site with a non US bike?
- AussieGold
Roncar is absolutely right. the on off for the headlight was also on the AU models, also on just about every other honda i have had. but..our little cb250
does nt . that is 2001 model.
my goldwing control has the seperate on off for headlight. i suspect it may have been a US requirement to have a constant headlight.
Mentor to all self appointed (and genuine) GURUS.
An LTD is........it just is.
Thanks Roncar and Aussie. I like it and I think I'll keep it. I wonder where the PO got it?
