If you have an outdoor grill, plunk the whole set into a big pot full of boiling distilled water for 10 or 15 minutes. Most of the crud and stuck things will come free of the outside.
transitman wrote:Managing one more post before we go on holiday for 3 weeks.
A few little things, some puzzles.
And here's something really grim, took the rear brake master off and prized back the cover - full of rust! Must have leaked brake fluid and corroded away. Many years ago. Might have to do some work on this before I put it back.
What probably happened was the rubber boot that was designed to keep water out may have let water in and not back out. That seems to happen a lot.
And my second puzzle is the what I presume is the water pump next to it. (really must read that manual) Took the hose off and started to loosen the bolts but the top one moved a turn and then tightened up hard on me. If anybody has some history here I would be grateful. I've left it for now, see if someone can advise.
Be very careful with that bolt. Try turning it back in and work it back and forth slowly. You might try shooting some penetrant in there to help it. You may or may not actually get some in on the threads. Then after you get that bolt out clean the hole threads. Run a tap in the hole with some WD-40 or maybe just plain oil. You may think about getting a different bolt too and throw the old one away if it had that much corrosion on it.
transitman wrote:snip.......
hope you can make it out, the camshaft retainer is covered in a crazing of what look like tiny cracks.
Anyone seen this before?
