40 Build
pierce
My Album: pierce
Re: 40 Build
Post by pierce »
Before installing the main shaft the 'guides' need to be placed in line. There are three, two smaller half circles, and one larger one.
Then just place them into the groove.
1976 GL1000
1978 Gl1000
Neil
Re: 40 Build
Post by Neil »
This has been enjoyable to watch. Great detail with the pictures.
Re: 40 Build
there is a large piece of sheet metal type stuff that goes in before the guide. has a rubber edge around it. kind of a splash guide. its molded to fit the bottom of the case, and the rubber guide mounts to it. or is that in the other case
joedrum
Re: 40 Build
Post by joedrum »
hmmm neat stuff
1979 1000
pierce
My Album: pierce
Re: 40 Build
#20
Post by pierce »
Cyborg, which part are you referring too. Want to make sure I haven't missed anything.
1976 GL1000
1978 Gl1000
pierce
My Album: pierce
Re: 40 Build
#21
Post by pierce »
Ok, I know what you are talking about Cyborg - I think it is this pieces that goes in the left case half (in the middle).
1976 GL1000
1978 Gl1000
Re: 40 Build
#22
ya thats it
Pony Ruiz
Re: 40 Build
#23
Post by Pony Ruiz »
very cool!
next best thing to youtoob :-D
subscribed
It is what it is.
Old Fogey
Re: 40 Build
#24
Post by Old Fogey »
pierce wrote:Remove the shift forks from the shaft, and orient them correctly. The tow outer forks go in the grooves on the countershaft, and the middle fork will fit into the main shaft, so it will just sit there (for now). Then slide the shaft through the opening and insert in into the forks. So far nothing has taken any force, just slides right in.
Forks are done.
Not quite!
Easter
Re: 40 Build
#25
Post by Easter »
Very helpful and great photos. Wish the manuals were as clear.
Thanks for sharing this.
Gary
83 GL in process :IDTS:
Re: 40 Build
#26
Man, this is great!
Looks like it will end up in ShopTalk.
pierce
My Album: pierce
Re: 40 Build
#27
Post by pierce »
Thanks old Fogey - I hadn't posted up on the pin just yet. will post the pictures as soon as I have a few minutes.
The pin holds the shift shaft in place from spinning as the very last gear (closes to the rear) will hit the shaft so it is indented on two sides. The pin hold the indent so the gear is free to turn.
I now have the main shaft, primary chain, chain guide, crank and oil seal in place. Pictures to come shortly.
1976 GL1000
1978 Gl1000
rod willis
Re: 40 Build
#28
Post by rod willis »
Good pic. and info but i see one thing missing and that is the main caps for the crank
i hope that you have them.
Rod
rod willis
1976 GL1000
pierce
My Album: pierce
Re: 40 Build
#29
Post by pierce »
Rod, In those pictures I haven't installed the crankshaft. All that has been installed in those photos is the drum, countershaft, chain guide, chain oiler and the shifter forks.
1976 GL1000
1978 Gl1000
pierce
My Album: pierce
Re: 40 Build
#30
Post by pierce »
Christmas came early! Received my vesrah complete engine gasket set, and a whole slew of oem Honda stuff complete with all engine oil seals needed, new dowels and a few other odds and ends that I needed to complete the engine.
So, next step is to get the main shaft, primary chain and crankshaft in.
1976 GL1000
1978 Gl1000
