Lester Wheels - Tube or Tubeless - definitive answer
Recycled Roadkill
Re: Lester Wheels - Tube or Tubeless - definitive answer
Post by Recycled Roadkill »
Did Lester quit producing wheels when the factory burnt down?
Bob Gill
'77 Honda GL 1000 Black Mamba (Sold) :(
alwing17
Exceptional Member
Exceptional Member
Post by alwing17 »
Yes they did... More companies were producing bikes w/mag wheels,so the writing was already on the wall..Just like Craig Vetter and the fairings and luggage. Honda figured it out in 1980 and made the Interstate.
1975 GL 1000 "Street Fighter"
1976 GL 1000 "Screaming Yellow Zonker"
1976 GL 1000 Sulfur Yellow x2
1981 GL 1100 "Crown Royal"
1997 GL 1500 Pearl Sapphire Black
1977 GL1000 Cirrius Blue
1977 GL 1000 Skidmark build
1976 GL 1000 Limited
2003 ST 1300 Silver Streak
(And those are just the Gold Wings! With an exception..)
Team 898...25%er...*Beverages Consumed
Team LTD...1/6th'er...* Even more beverages consumed
Thank you for posting, now I have the confidence to remove the tube from the front next time I replace the tire. Way easier to put in a plug on the road.
Old Fogey
Post by Old Fogey »
Not trying to add fuel to the fire, but I have only had two sets of Lester wheels in my hands; the one set NOS still in their very damaged boxes and the other used. One set had large valve holes which would accept a tubeless valve, the other set had small holes that could only take the valve stem of a tube. Unfortunately I did not check out the rim shapes, as I thought that the usage was self evident.
wingrider
#20
Post by wingrider »
I will have to check the ones I just bought...they are both new in the box. Special additions none the less! :-D
#21
I have come across both valve sizes. I used a small passenger car valve stem on the smaller one and a larger truck valve stem on the larger one. My local tire shop helped me figure out each one.
BlueThunder
#22
Post by BlueThunder »
I've had 2 sets of Lesters... one in 1981 and the other in 2015. Both were/are tubeless.
...Brian
1977 GL1000 - Ox
Patriccio
#23
Post by Patriccio »
Good job, Doctor Archivist.
calif wingnut
#24
Post by calif wingnut »
18" lester on a 78 I parted out many years ago.
