Darn Goldwings.....The Holley project
Re: Darn Goldwings.....
Looks like a good place to start. I just started on another project (it just looks like Trash II ) and I think the only thing salvageable will be the frame and hopefully the engine, but it has a title!
- Oldboy
Well it's been a while. Watch this Youtube video...
http://www.youtube.com/watch?v=5z-38tVq ... e=youtu.be
The Holley project begins! What you see is a 1958 Rambler 250 c.i. V8 Holley carburetor on a exhaust pipe and 1/4" steel homemade intake.(Bobber style!)
It's the same as a 1957 Thunderbird carb only cheaper on ebay. It only flows about 390 cfm. The venturi's size is 1 1/16" and the throttle plates are 1 7/16". This is the same size as the newer 390 cfm's sold by Holley, except that this is a 4150 series vs 4160 series. The difference is the 4150 series carbs have a metering block in both the primary side and the secondary side whereas the 4160 use a metering plate in the secondary side which makes jet changing more difficult because you have to change the whole plate as opposed to just changing jets like the primary side. I also added the cathedral float bowls found on larger Holleys, just to give it that BIG look. Please pardon the plumbing, it's only mock up for tuning.
A little mock up for centering..
Float bowl difference....
This is an intake heater- carb icing was a bit of a problem. I closed the bypass passage between the thermostat housing and the waterpump inlet. Then I tapped into both housings with a 5/16" barb. I ran a hose from the thermostat housing to the top of the copper plumbing, then returned it to the inlet of the waterpump. The video doesn't show this very well. It still runs poorly until it warms up thoroughly, but its winter here and pretty cold!
Here's the whole thing on the bench.
Gotta love that Cal Custom scoop!!
More later..........
Cheers...
Just Wing-it
Just Wing-it
WOW, now that is a tunnel ram.
Will you be able to open the shelter to fuel up? In the pic it looks awfully close.
I like it!! Whether it runs or not! (We- my family-once owned a '58 Rambler but that isn't why I like it.)
Holy Freakin Crap!!! I am in Winnipeg, and I know I just heard Greg Foresi guffaw all the way from Michigan!!! Cool factor=10.
This needs to be retitled.
- Oldboy
Hey Robin, Yeah the shelter door just clears the rear float bowl. Hopefully I can modify the front lid to cover the exposed area around the plenum.
Cheers...
Just Wing-it
Just Wing-it
- HOTT
Re: Darn Goldwings.....The Holley project
Low flying birds beware!!
Awesome!!
- brianinpa
That is quite impressive!
Brian
ADC(AW) - US Navy Retired 1983-2003
If you aren't having fun doing it, find something else to do.
1984 Standard - 18,000 miles - Naked... the way it should be
1987 Interstate - 62,000 miles - Resurrected from the rust bucket
- hmratbam
Well I don't have to wait any longer! I've been wanting to see a 4 bbl Holley on a 'wing.
My Album
84 Standard ongoing project
My Album
- bladredhead
OMG. That is so Roth.
- Oldboy
Roth, yeah..I like that. Also going to do Cherry Bombs & dump pipes!
Cheers...
Just Wing-it
Just Wing-it
- evilratwing
- My Album: http://www.photobucket.com/evil03ratwing
I'm diggin it.
The bike is essentially just another bike... The pilot is CRAZY.
Whargoul - Murdered out 1978 GL1000 - Engine KaBOOM.
Cherry Cough Syrup - 2009 Suzuki M90 - 3,300 miles.
- joedrum
hmmmmmm what kind of meds you been on oldboy.....LOL yep this is something ... the whole idea it runs is success big time ...
1979 1000
