Help: Runs worse after timing
- jdvorchak
Re: Help: Runs worse after timing
Now that I re-read your original post I have to think you have a dead miss. Have you run a compression check to make sure have compression? The simple fact is that you need air, gas and a spark at the right time but that only applies to a healthy engine. For all you know one of the pistons has a hole in it or is missing entirely... Don't laugh.. I bought a CB900 once that only had 3 pistons and rods and it started and ran!
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- groupus
- Location: Lancaster Pa, USA, Earth, Solar System, Milky Way
That would be interesting, although I did find all 4 when I changed both head gaskets. I remember doing a compression test when I was diagnosing a blown head gasket and I think I checked it after too.
Obviously something is wrong with the sequence of suck, squeeze, bang, blow
Fyi: Dyna is on Amazon prime for $133...
Faster, faster, faster, until the thrill of speed overcomes the fear of death. ~Hunter Thompson
every now and then, when things are not going to well in the shop, i ask myself why i do it. and the answer is that riding is good....but time in the shop is also good. - CYBORG
78 gl1000 cafe build: http://ngwclub.com/forum/viewtopic.php?f=30&t=51461
79 full fairing - current status: Haunted http://www.ngwclub.com/forum/viewtopic.php?f=1&t=60334
- groupus
New update: I switched the entire points assembly from the other bike and reset it and the issue persists. So far I've ruled out the carbs, ignition, timing, resistor caps. I guess I'll get another set of spark plugs and swap some coil wires around. I'm running out of things to try. The thought that it could be a dead cylinder is a possibility, but everything did look fine when I had the heads off.
I'm still wondering if the advance unit is working. Have you checked it?
- jdvorchak
In my mind you have not ruled out the carbs. If that header pipe is still colder than the others and you say you have compression and spark what else is left?
2021 HD Triglide
John
2021 HD Triglide
John
I agree with jdvorchak on this. 'One and done' on these carbs isn't always true, even for the most experienced wrenches. Not trying to knock your ability, just saying...jdvorchak wrote:In my mind you have not ruled out the carbs. If that header pipe is still colder than the others and you say you have compression and spark what else is left?
- Griffen
I may have missed it but have you checked your coil and coil wires?
Present Projects
1983 GL1100a
1976 GL1000
Past Rides
1975 Honda 500t
1976 Sportster
1981 Honda cb750
1999 Honda VT1100t
1999 K1100ltc
1983 GL1100a
1976 GL1000
Past Rides
1975 Honda 500t
1976 Sportster
1981 Honda cb750
1999 Honda VT1100t
1999 K1100ltc
- groupus
I can certainly never rule out the carbs, but they are definitely low on the list now. this is the 3rd time I've cleaned this particular set: once in-situ, once completely disassembled but without replacing anything, and finally a complete overhaul again with the Randakk master kit. Plus it did exactly the same thing with the 1100 carbs off of my good running '78 gl1000 which were also rebuilt probably 1000 miles ago. Plus, I've seen bikes run with some pretty haggard carbs. Again, not completely ruled out, but I'm 98.9% sure they are not it.
SOOOO here's the really interesting thing: if I hook up a timing light to the #3 lead, it flashes sporadically. All other cylinders flash fast and consistent. I replaced the spark plug, swapped the resistor caps, checked the valve clearances, and even swapped the coil wires (because it is a wasted spark system, you can swap the #1 and #3 wires with the #2 and #4 wires and it will fire the same). Still, #3 is always the dead one. If it were any one of those components, it would affect a different cylinder. This is crazy!
Now to steal some Coils! My poor naked bike is becoming a parts mule
Edit: Oh also, I did check and lube the advance do-hicky, seems fine. And if I pull the plug for #3 while it is running, it gets worse, so it is doing something, not completely dead.
- jdvorchak
Ok I concede that it's not your carbs. so swapping the plug wires didn't help that leaves only the coils. Must have a bad tower on that coil to the #3 cylinder. Easy enough to test. Swap the plug wires side to side on coil. See if the problem doesn't move to #4.
2021 HD Triglide
John
2021 HD Triglide
John
- groupus
The crazy thing is that I did swap the plug leads side to side - #2 and 4 on #1 and 3 cylinders - and it did exactly the same thing! That makes no sense to me. Yes, it should have transferred the issue to #4 if it was the coil. Finally, I did steal the Dyna coils from other bike and it ran better. Not perfect, but better. There is still some missi-ness in the strobe light on #3. but not nearly as bad as it was. My expert conclusion is that the cylinder is haunted and the whole bike needs an exorcism.
In other fun news, I went to ride it to work this morning. It fired right up, idled and took off fine, but then it stalled and would not restart. It's definitely haunted.
- salukispeed
IF you are using an inductive timing light it is important to have the pickup/clamp oriented the correct way and since these are a waste spark system the direction the current passes through the cable is opposite. On my light I need to flip the clamp over to get it to flash reliably . It sounds odd but is true. The arrow on my clamp needs to point away from the plug on one side and towards the plug on the other.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
- groupus
That is very interesting and may explain what I am seeing. Either that or mild psychosis.salukispeed wrote: The arrow on my clamp needs to point away from the plug on one side and towards the plug on the other.
- salukispeed
I have what I think is a quality light ( Snap On ) but it is finicky how the clamp is positioned. It is old 20 years
Honda 72 CL100 sold
1970 CT 70
1970 CT 70
Bad plug maybe, How were you checking for spark?
- VintageMan77
I am a fan off the C5 - take a hard look at Paul's set up before popping on a Dyna.
Cheers,
Chris
1977 GL1000
1968 Suzuki KT120
1981 Kawasaki Spectre 1100 (sold)
1983 Suzuki GS 550 (RIP)
1981 Yamaha Maxim 400 (where it all began...sold to a girl named Rebel)
"The only thing harder than learning from experience is NOT learning from experience" EMR
Chris
1977 GL1000
1968 Suzuki KT120
