Critique my manifold heating!
Toehead
Re: Critique my manifold heating!
Post by Toehead »
Here is a picture of how the GL1200 EFI setup works. This is on the EFI motors, not the carbed. However, I bought mine on ebay for only a few bucks.
Water pump with extra host nipple
Thermostat housing with extra sensors and hose nipple.
They bolt right on with a small tab that you need to cut off the top of the motor (it's only for lifting and wasn't on the fuel injected models)
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
Oldboy
Post by Oldboy »
Toehead is right...that's exactly what I did to mine. I drilled & taped both housings using 1/8" pipe thread
fittings. (I didn't know 1200's had this). I also plugged the original bypass port (in the water pump housing).
This forced all the coolant through my intake heater during warm up.
Cheers...
Just Wing-it
Fuzzy head is telling me it was only 1200 efi models which had this. One of mine has this (efi) the other does not.
Toehead
Post by Toehead »
Yes, that's correct. I'll edit my post.
1980 CB750C (sold)
