Don't you need a whole setup for that?maury wrote:Soda blast.......... quick, thorough, complete, simple. Grab some at Harborfreight
Cleaning my Engine
- BigBrian27
Re: Cleaning my Engine
1975 Honda GL1000 Goldwing
1992 Kawasaki Concours ZG1000
Solid rotors suck! I have the PDF for the rotor drilling template, PM me if you would like a copy.
- Toehead
Nah, I used the spot blaster, also from harbor freight. It works wonders on carbs.
Makes a mess and not as fast as a true soda blaster, but works well.
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
Here's what I use with sand, soda, glass. I just go out in the yard (I have a huge back yard), stick it in the bucket and GO !!BigBrian27 wrote:Don't you need a whole setup for that?maury wrote:Soda blast.......... quick, thorough, complete, simple. Grab some at Harborfreight
Eastwood.com Cost $ 30.00
76 GL1000 LTD
2019 DCT Airbag Tour
Austin, Texas
76 GL1000 LTD
Austin, Texas
- BigBrian27
Now that's a cool idea!maury wrote:Here's what I use with sand, soda, glass. I just go out in the yard (I have a huge back yard), stick it in the bucket and GO !!BigBrian27 wrote:Don't you need a whole setup for that?maury wrote:Soda blast.......... quick, thorough, complete, simple. Grab some at Harborfreight
- Earl43P
This is a quote from the Simple Green website:
"Is it safe to use Simple Green on aluminum?
Simple Green products have been successfully and safely used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: Aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green or Crystal Simple Green can accelerate the corrosion process. Therefore, contact times of All Purpose Simple Green and Crystal Simple Green with unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green/Crystal Simple Green residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation."
2008 GL1800 "yawn"
KTM390A “Hootinanny”
04 ST1300 DDDD (Double darksided daily driver) Sold 4/2022
93 GL1500I Double darksided and SOLD 3/29/20.
99 Valkyrie IS, Fast Black Double Darksided
"Fishtailed, flipped and flung me, but wearing it well". Sold!
82 GL1100 retired DD, needs work.... Sold 3/3/17
- BigBrian27
Thank you for posting that. That is good information. I will let it sit for 10 min and hose off.Earl43P wrote:This is a quote from the Simple Green website:
- mcgovern61
I have used Gunk SC-II concentrate mixed with diesel fuel and it will cut through any grease. Here is what I started with:
After cleaning and painting:
Gerry
Current ride: 82' GL1100
1st ride: 81' Suzuki GN400
- BigBrian27
mcgovern61
That looks awesome! Nice job. What paint did you use?
- propav8r
- mcgovern61
Duplicolor Aluminum engine paint plus high heat clear.BigBrian27 wrote:mcgovern61
Gerry
- BigBrian27
Looks fantastic! How's it holding up?mcgovern61 wrote:Duplicolor Aluminum engine paint plus high heat clear.BigBrian27 wrote:mcgovern61
- mcgovern61
It held up great for several years.
Then I went and changed the engine color to Duplicolor Iron which I really like. This paint shows off the polished aluminum, chrome bolt heads and and black hoses nicely (IMHO).
Gerry
- BigBrian27
Wow that looks awesome!
Now i'm getting all kind of ideas
- kerryb
I started with s100, then soda blasting, the kerosene, bamboo barbecue skewers and a toothbrush. Took a long time, but the new paint is sticking well and I'm pleased with the results if not the time spent. Soda blast wouldn't take off the packed in oily crud. That required scraping with a bamboo stick.
- mcgovern61
Next time I do any out of bike work on the engine, I want to add to the Iron paint scheme and change the color on some of the accent pieces like the filler cap, stator cover, fuel pump and such to a gun metal. I saw someone do this on another engine and I really like the accents!
Gerry
- 3 Replies
- 2206 Views
Last post by mikenixon
- 7 Replies
- 1997 Views
Last post by Old Fogey
- 15 Replies
- 1567 Views
Last post by 77Gowing
- 10 Replies
- 555 Views
Last post by Graham Cracker
- 13 Replies
- 1125 Views
Last post by 82aspy
