This one is going to BLOW your mind!
Re: This one is going to BLOW your mind!
Now I have another reason to make it to the Stockbridge event
Yum! If I may ask, where do you get your wiring supplies, i.e. fuse blocks, connectors, etc.? Me like!
Easter
Post by Easter »
Stockbridge, Used to be my home neighborhood but it is a bit far now.
83 GL in process :IDTS:
duke182
My Album: http://ngwclub.com/gallery/v/wingmans/duke182/
Post by duke182 »
Thanks for the update.
Looking great
1984 1200 standard
click pic to see my gallery
vote in my poll
chewy999
#20
Post by chewy999 »
Looks fantastic! Hope it starts :shock:
anim-cheers1 anim-cheers1
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Old Fogey
#21
Post by Old Fogey »
JR, what are the brake and clutch masters off? Interesting shape.
Graham Cracker
#22
Post by Graham Cracker »
action1 action1 action1
Mark
1976 GL 1000 Sulfur Yellow
1977 GL 1000 Pearl White
CBX-tras
#23
Post by CBX-tras »
Track T 2411 wrote:Yum! If I may ask, where do you get your wiring supplies, i.e. fuse blocks, connectors, etc.? Me like!
My primary supplier is Waytek in Chanhassen, Minnesota. Even though they're a couple of states away, I can have items shipped to me at a lesser cost than going to a supplier right here in town.
When my local supplier jumped the price of one of the most common terminals that I use to $0.44 each, Waytek was at $0.12. And when I buy them by the thousands, that's a HUGE difference.
See here:
https://www.waytekwire.com/
BTW, I found that I can spec the items I need faster from their paper catalog. Nice folks to work with.
CBX-tras
#24
Post by CBX-tras »
Old Fogey wrote:JR, what are the brake and clutch masters off? Interesting shape.
Kawasaki 1400 Concour from 2009 to 2014. Made by Nissin, 19mm bore, radial design, can be found relatively inexpensive on eBay.
CBX-tras
#25
Post by CBX-tras »
CBX-tras wrote:
Kawasaki 1400 Concour from 2009 to 2014. Made by Nissin (brake supplier to Honda too), 19mm bore, radial design, can be found relatively inexpensive on eBay.
No mirror mount if that's a concern but, mirror mount half clamps are available in the aftermarket.
Sugs
#26
Post by Sugs »
Wow, awesome work. Is the front end off a different bike? Just wondering how you managed the floating rotors.
_______________________
'79 Honda GL1000 Goldwing
CBX-tras
#27
Post by CBX-tras »
Sugs wrote:Wow, awesome work. Is the front end off a different bike? Just wondering how you managed the floating rotors.
The front suspension is a collage of parts, legs are CB900F, lower triple is CB1100F, upper triple is from a ProLink CBX, springs and emulators are from Racetech, calipers are 4 piston progressive (2 different size pistons) Brembo held on via Metalgear Works brackets and the 320mm rotors are from SunStar in Japan. They're made for some Suzuki (not available in the USA) but I re-machined the center and bolt pattern to attach to the Honda hub.
Wheels were custom built for me by Buchanan in California.
The bars started out as clip-ons made in Japan (unknown mfg.) that I highly modified to achieve the fit/function I was looking for. Front fender is from a Yamaha FZ6R, the rear fender I sectioned from stock, bobbed about 6 to 7 inches.
Old Fogey
#28
Post by Old Fogey »
19mm is too big for the dual piston 1100 calipers I'm running. Ah well. :(
CBX-tras
#29
Post by CBX-tras »
Old Fogey wrote:19mm is too big for the dual piston 1100 calipers I'm running. Ah well. :(
Not true. Just less effort.
Works like one finger power brakes. Here's a photo of the first bike I did using that m/c, years ago. Same calipers as the 1100, stock rotors. The results will amaze you.
Sugs
#30
Post by Sugs »
CBX-tras wrote: The front suspension is a collage of parts, legs are CB900F, lower triple is CB1100F, upper triple is from a ProLink CBX, springs and emulators are from Racetech, calipers are 4 piston progressive (2 different size pistons) Brembo held on via Metalgear Works brackets and the 320mm rotors are from SunStar in Japan. They're made for some Suzuki (not available in the USA) but I re-machined the center and bolt pattern to attach to the Honda hub.
Doh! OK then, not something I'm going to attempt. Some serious parts research, modding and fitting there. How about the rear shocks?
I did notice the bars, not something I've ever seen, pretty trick.
And maybe its just the picture, but the headlight seems a little high and out there. You planning on tucking it in a little, more like the bike in your avatar?
