Small Mystery Spring in Forks Not On Parts Fiche
- jdvorchak
Re: Small Mystery Spring in Forks Not On Parts Fiche
Personally I stick with what the FSM says and use ATF. It's all hydraulic oil and ATF is widely regarded as 7w. If you do decide on fork oil I'd start with no heavier than 10 w because new springs will be plenty stiff to begin with. I'm afraid that 15 or 20 w will be bone jarring.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- Dirty Dave
I'm happy with 15 weight fork oil with the Progressives. Not stiff at all with the 79 Wing.
1979 GL1000
1997 Honda Valkyrie
2018 Kawasaki Z900 RS
1975 CB750F (sold & dead)
1978 Gl1000 (sold & sleeping)
1984 Aspencade (sold)
1997 Honda Valkyrie
Dirty Dave wrote:I'm happy with 15 weight fork oil with the Progressives. Not stiff at all with the 79 Wing.
What works for one person doesn't always work for others though. Whiskerfish had Progressive springs in one of his and it was way too harsh for him. I have Progressive springs with the forks shortened internally. Very stiff but it is what I wanted.
- Dirty Dave
I'm 220 lbs so I guess I'm pretty porky compared to you two. In my defense I am 6' 4. My Valk is too stiff with that setup though.
1979 GL1000
1997 Honda Valkyrie
1997 Honda Valkyrie
- BigBrian27
At 6'7" 250lbs I'm built similarly to you no doubt. Perhaps I'll try 10wt oil first.Dirty Dave wrote:I'm 220 lbs so I guess I'm pretty porky compared to you two. In my defense I am 6' 4. My Valk is too stiff with that setup though.
1975 Honda GL1000 Goldwing
1992 Kawasaki Concours ZG1000
Solid rotors suck! I have the PDF for the rotor drilling template, PM me if you would like a copy.
I thought your bike looked pretty small next to you in some of your pics, hence, the bigbrian. I'm 5'10" and shrinking fast but still push 190-200lbs. When I go from my hybrid 1000 with 41mm forks to my stock 1000 with 37mm forks I am alarmed at the flex in them. I have a fork brace too.
- BigBrian27
Im kicking myself for not upgrading to larger forks but oh well I'll make these work.ericheath wrote:I thought your bike looked pretty small next to you in some of your pics, hence, the bigbrian. I'm 5'10" and shrinking fast but still push 190-200lbs. When I go from my hybrid 1000 with 41mm forks to my stock 1000 with 37mm forks I am alarmed at the flex in them. I have a fork brace too.
Can do it later. 1200's fit the easiest, but 41mm sport bikes might give better performance.
- 11 Replies
- 631 Views
Last post by Whiskerfish
- 7 Replies
- 472 Views
Last post by Old Fogey
- 15 Replies
- 1558 Views
Last post by ericheath
