fan switch Q?
Re: fan switch Q?
Re: fan switch Q?
It looks just like stock except the end bulb is brass not copper. The wiring is the same also. Starting the threads straight is a chore because a socket holds it on an angle, I loosened the bottom of the radiator and lying on the driveway I was able to get my hand in there enough to get it started, then tightened it with a socket on a swivel extension.
Re: fan switch Q?
Tks. If mine doesn't work I will get one of these. If you loosen the rad enough to get the heat shield out from behind the fan motor it gives you a decent working space.Don R wrote:It looks just like stock except the end bulb is brass not copper. The wiring is the same also. Starting the threads straight is a chore because a socked holds it on an angle, I loosened the bottom of the radiator and lying on the driveway I was able to get my hand in there enough to get it started, then tightened it with a socket on a swivel extension.
- 11 Replies
- 1799 Views
Last post by alwing17
- 1471 Views
Last post by Track T 2411
- 14 Replies
- 3412 Views
Last post by ScottyDog
- 7 Replies
- 1304 Views
Last post by 5speed
