balls or taper?
Re: balls or taper?
rcmatt007 wrote:only to make the choice tougher
LOL, yup. We had a discussion on the mid year change some time back. I think that narrowed it down to when the change was made.
roncar
Re: balls or taper?
Post by roncar »
rcmatt007 wrote:kit number 75-76 is 22-1011 and 77-79 is 22-1020
robin1731 wrote:There was a mid year change on the 76. Early 76's take a different kit than later ones. I found this out when doing the Super Sport Wing.
robin1731 wrote: LOL, yup. We had a discussion on the mid year change some time back. I think that narrowed it down to when the change was made.
Keep in mind that the change was from ball bearings to the later (77-79+) tapered pins. If you have balls, you need the early kit (22-1011).
According to the parts list:
balls thru frame #2040165 (same as 75)
tapered bearings from frame #2040166 (same as 77)
Re: balls or taper?
Saturdays project.... take the stem out and see
Old Fogey
Re: balls or taper?
Post by Old Fogey »
On early 76 and 75 use the CX500 kit
Re: balls or taper?
#20
I'll throw a wrench in that. My 76, the Super Sport Wing had ball bearing from the factory. But the all balls tapered bearing kit for a 1976 Wing did not fit. It's been 10 years so I don't remember what it was. And I don't remember which kit I bought either.
Re: balls or taper?
#21
order two?
Gowing
Re: balls or taper?
#22
Post by Gowing »
Used Boss Bearing.com perfect fir for my 75.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
Re: balls or taper?
#23
took out the stem and sure enough.....
drum roll......
BALLS! Now the question is simply do I repack them or drive out the races and replace
Rednaxs60
Re: balls or taper?
#24
Post by Rednaxs60 »
Since you are refurbishing the bike and do not know the history for the steering stem bearings, my vote would be replace with taper bearings. You've got the steering stem out already.
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2008 GL1800 (sold)
tlbranth
Re: balls or taper?
#25
Post by tlbranth »
rcmatt007 wrote:I have used them on my 78 and 79. I know the steering stem is different on a '75 and you cannot put tapered bearings on it, but I am uncertain about the 76
I put All Balls steering bearings in my '75.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Re: balls or taper?
#26
yes, as it turns out, ALL BALLS makes two different sets. the vendors on ebay often list them incorrectly
