'90 GL1500 Gone Wild
Chipsnsit
Zinc Member
Zinc Member
Re: '90 GL1500 Gone Wild
Post by Chipsnsit »
5speed wrote: Fri Mar 12, 2021 9:13 am I take it your wing is fuel injected?
do a carb swap and get rid of all the electronics except for an ignition source. :mrgreen:
It has dual carbs. If I understand you correctly though, then what BobManifold is saying about keeping “7 wires” is accurate. Cap off all the vacuum lines and ditch a bunch of sensors and electronics. Change the jets in the carbs for a larger set and then go for a ride.
hoganJr
Post by hoganJr »
You're in way deeper than I can go. It's all I can do to troubleshoot and maintain my '91 GL1500 and put it all back together again!
HoganJr
1991 GL1500
Chipsnsit
Zinc Member
Zinc Member
Post by Chipsnsit »
hoganJr wrote: Fri Mar 12, 2021 9:30 am You're in way deeper than I can go. It's all I can do to troubleshoot and maintain my '91 GL1500 and put it all back together again!
HoganJr
:lol: Well I hope it helps you if you ever decide to slim down some features. I was trying to build a wire map that would make sense and I can upload screenshots or post a document library with what I have made so far. I am thinking that some of the sensors and systems on there help it run smooth with all the original hardware but since I am cleaning all of that off the bike and really just keeping the frame and motor I really only need the “essentials”. I think I will take what I have and make a separate tab that breaks out the “essentials” so you can see the whole system and see the minimum in case someone that knows enough to be dangerous wants to try and build a middle ground, like what Pedro is doing.
5speed
Post by 5speed »
Chipsnsit wrote: Fri Mar 12, 2021 9:29 am
if it isn't injected than you don't need the o2 sensor, throttle position sensor,etc,etc,etc. If they even have that. None of my bikes are young enough to drink from an injector. :-D
Chipsnsit
Zinc Member
Zinc Member
#20
Post by Chipsnsit »
5speed wrote: Fri Mar 12, 2021 10:00 am if it isn't injected than you don't need the o2 sensor, throttle position sensor,etc,etc,etc. If they even have that. None of my bikes are young enough to drink from an injector. :-D
Did some poking around and the only thing I am trying to sort out now is the pulse generators. Seems like the ECU has some magic to make sure it fires the in an order.
The pulse generators tie into the (TA) and (TW) sensors and to pins 5,7, & 8 on the ECM. Maybe the ECM is using this as a ground or those to do math and determine when to activate the ignition coils? :dunno:
Chipsnsit
Zinc Member
Zinc Member
#21
Post by Chipsnsit »
Good evening all,
I took some more stuff off yesterday, the front subframe that guides the speedo cable and holds the air temp sensor. It also is where the radiator screen is mounted so I need to fabricate a location to hang that now. I ordered some parts to get me started on my rewire, front turn indicators, rear lights (in the form of an LED strip), left side control replacement (still need to replace choke control though), a new starter relay and a motogadget m.unit to replace OEM relay/fuse boxes. I am probably still missing something. :dunno:
Anyways, I have been drawing out what I think is going to work for accessories, but I haven't figured out what pin is pushing power to the ignition module(ECU).
#22
Really good diagrams here but I think it starts at 94 model https://www.goldwingfacts.com/threads/g ... am.636674/
sgwilly
#23
Post by sgwilly »
You might want to take a look at a 1500 Valkyrie wiring diagram. Same engine, just without all the additional gizmo electronics. Also carbureted, but with 6 instead of two. It may be a blueprint of what you need.
Steve
'09 Yamaha FJR1300AE
'99 Valkyrie Tourer
'89 Isuzu Trooper 3.4L
'83 GL1100 MonkeyWing (on IR)
'75 GL1000 (in the queue)
'64 MGB
IBA #58082
SGWilly Gallery
Chipsnsit
Zinc Member
Zinc Member
#24
Post by Chipsnsit »
Whiskerfish wrote: Mon Mar 15, 2021 7:56 am Really good diagrams here but I think it starts at 94 model https://www.goldwingfacts.com/threads/g ... am.636674/
Thanks, I have been staring at these a lot this weekend, well this last almost year actually. I have the Honda service manual for my bike so I cross reference it since it’s not colored. anim-cheers1
sgwilly
#25
Post by sgwilly »
I can PM you a color schematic for the Valk if you need it.
Steve
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
Chipsnsit
Zinc Member
Zinc Member
#26
Post by Chipsnsit »
sgwilly wrote: Mon Mar 15, 2021 10:33 am I can PM you a color schematic for the Valk if you need it.
Let’s give that a go, it might unlock something I’m missing.
I am pretty confident I am missing some technical knowledge. I should lean more into my service manual at this point.
sgwilly
#27
Post by sgwilly »
PM sent. Let me know if you didn't get it. I can't quite figure out what the difference is between the "out" and "sent" directories are in PMs.
Steve
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
Chipsnsit
Zinc Member
Zinc Member
#28
Post by Chipsnsit »
sgwilly wrote: Mon Mar 15, 2021 5:02 pm PM sent. Let me know if you didn't get it. I can't quite figure out what the difference is between the "out" and "sent" directories are in PMs.
I got it, thank you. It looks like it takes a bit for a PM to get picked up from the "outbox" but once it is picked up it is then officially "sent".
#29
Chipsnsit wrote: Tue Mar 16, 2021 4:25 am
A PM sits in the out box until the person you sent it to opens it. It may sit there a day or less or a week or much longer. But it sits until they open it. That way you know when they read it. This question comes up about every other month or so. ;)
Chipsnsit
Zinc Member
Zinc Member
#30
Post by Chipsnsit »
Good to know, never thought it would play out like that. Thank you!
