Another 76 GL1000 Recovery
Re: Another 75 GL1000 Recovery
while you have it all apart, I would swap out the water pump...because that bakelite one is probably 47 years old
leonardhcross wrote: Thu Nov 17, 2022 10:01 am The water pump is bakelite but has no extra play in it. Would you leave it or swap it out?
I'd swap it out. I did one a few years back that was solid just like that. It leaked pretty bad at first start up and never stopped. :roll:
leonardhcross
Post by leonardhcross »
Thanks for the replies. I will go ahead and swap in a new water pump. I was hoping to avoid removing the front engine cover. The bolts are the original phillips head bolts and are pretty rusty. I have done it before with my first bike and did find that using a decent, long pyillips head screwdriver and giving it a good rap with a hammer worked.
the phillips used by honda are a little different than what we use. the tip of the bit is flattened off, so be sure to use thaat kind as the us ones will want to spin and tear out the slots.
pidjones
#20
Post by pidjones »
Yes, buy a good set of JIS bits and if the crews haven't been buggered already, they should not wallow out (might snap off, though).
#21
pb blaster and time is your friend. btw you can still get an original honda transmission gasket from david silver spare.
#22
pidjones wrote: Fri Nov 18, 2022 5:10 pm Yes, buy a good set of JIS bits and if the crews haven't been buggered already, they should not wallow out (might snap off, though).
yeah, I hate dealing with buggered crews lolol anim-cheers1
leonardhcross
#23
I'm with you Rodger. Buggered crews are the worst. BTW, the first thing I did when I got this bike home was to hit every screw , nut and bolt with PB Blaster. Then I repeat the process for a few days.
leonardhcross
#24
Who or what is "david silver spare"?
#25
leonardhcross wrote: Thu Nov 17, 2022 6:24 pm Thanks for the replies. I will go ahead and swap in a new water pump. I was hoping to avoid removing the front engine cover. The bolts are the original phillips head bolts and are pretty rusty. I have done it before with my first bike and did find that using a decent, long phillips head screwdriver and giving it a good rap with a hammer worked.
Cliff ;) )
#26
leonardhcross wrote: Fri Nov 18, 2022 6:05 pm Who or what is "david silver spare"?
David Silver is an aftermarket parts supplier
#27
they also have a lot of NOS honda parts
pidjones
#28
Post by pidjones »
Along with Motopro hex drive bits, I have two of the Vessel JIS impact drivers, and they haven't buggered a crew yet.
#29
A good Bakelite part is just that. Run it.
Dr. Frankenstein
#30
Post by Dr. Frankenstein »
I have a set of the Vessel Megadoras and they work well, although I've only had limited success with the Impact one; but I won't touch a Japanese bike without them. As far as the hard-to-remove screws, adding a little valve lapping compound to them helps the screwdriver bite more. You can also try this method, which I've had a lot of success with:
Put some compound in the head notches, get a good grip on the screwdriver shaft with the vise-grips, push in on the screwdriver and crank that sucker loose by leveraging the vise grips. Often times they will *snap!* loose.
