so what's next? maybe a 78 and a 77?
- NotSoLilCrippseys
Re: so what's next? maybe a 78 and a 77?
Here's a not-so-great photo of the gusset on my '79. I think Pidjones has offered up one that's possibly a better reference if you're going to reinforce the frame you have.
In the Stable and Ridable
1978 CB550K - son's cafe
Sold
Sold
Yes saw it. My 78 has it as well
got scrubbing on the 77 engine and it cleaned up pretty good, also blasted a few of the spots. Always hate trying to clean the grime in the groves on the bottom. Did the head covers and timing belt covers in powder coat silver (they look better in person). and black powder coat for the center stand. The center stand will also get hit with some frame black when I paint the two frames.
took the heads off the 77 engine and everything looked great, so powder coated a lot of small parts and repainted the engine. the 78 was painted a couple of years ago, and is sort of a cast aluminum look, so I will so a light top coat of rattle can engine paint that looks more OEM (a lot of dust on the 78 engine)
started sanding on the 77 frame. It is in remarkably good shape considering the age. rust in the spots you would expect, but not bad at all. Hit it also with "rust neutralizer" in the spots it was difficult to sand/wire brush. The 78 frame was sanded and primed when I took the bike apart about 3/4 years ago. I will sand down the red primer as it is on top of the self etching primer, helps to see the little divets and scratches. Also made up a high tech tool to get the bearing races out of the steering stem. I might add, while the engine was very low miles some PO did change the timing belts, but I still replaced them with new
now for the fun part.... everyone should have a set of carbs on the kitchen table
Trade you for these.
well, I haven't looked inside yet.....
so I think that would be a fair trade with Robin... what y'all think? I got the 77 carbs off ebay several years ago. I noticed a idle screw kit (in the OEM bag) in the plenum, As I took it apart found there was a missing idle screw. toehrwise they look pretty darn good.
digschopper
I had some powder come out horrible( im a rank amatuer, first pieces) i scuffed it up with 80 grit and used paint stripper. It worked. Did you remove the chrome from your valve covers?
yes, used stripper and a course buffer. Did them in silver and they look much betterdigschopper wrote: ↑Mon Dec 19, 2022 11:46 am I had some powder come out horrible( im a rank amatuer, first pieces) i scuffed it up with 80 grit and used paint stripper. It worked. Did you remove the chrome from your valve covers?
a little powder coating can make things look new
now if I can only remember how it goes back together...
actually came out pretty good. I am still waiting for the shut off for the fuel into the bowls. Could not get one pin out and it looks like there was already a crack in one post.... just followed the Beatles and "let it be"
- ritalz
To me, the linkage was the worst part of re-assembly.
yeah, I had to re split the plenum to get the choke linage correct I kept the two carbs together with the chrome piece so I didn't have to reassemble that. the bowls and plenum were powder coated, and I used engine paint on the tops.
