Charging system
- gdonlo04
Re: Charging system
thank you for all the great details.
- gdonlo04
Re: Charging system
Ok update: Battery tested good and charged. New spade connectors installed with new plastic connector. New Regulator/ rectifier installed. Old Regulator removed. Went for a ride. Bike started up initially w/ issue. I stopped and waited to restart. Issue not resolved. Then this first started I took the start button apart and cleaned out all the just. A new Stator was installed 7000 miles ago. What is the next logical place to look?
Re: Charging system
What is the voltage at the battery at 3000rpm? At idle?
Did you load test the battery?
- gdonlo04
Re: Charging system
i took it to advance auto to test it. they told me it was good. i will run it and test it at 3000 rpms. get back to you with the results.
- gdonlo04
Re: Charging system
Well pulled the solenoid. This connection if fried too . New connector is ordered.
Re: Charging system
I'd replace wiring (make sure it is heavy enough for the current), connectors, and the dogbone fuse (replace that with a plug-in 30 Amp and holder from the auto parts store). And while you are at it, clean and/or replace any other connectors/wires.
- gdonlo04
Re: Charging system
I will thanks. Update once done
